How to remove lower dash
Old Nov 5, 2003 | 03:13 PM
SoCalTed's Avatar
does anybody have the steps to remove the lower dash in order to get to the wires supplying power to the cig lighter on the driver's side?
At least I am assuming you need to remove the lower dash and side of the console. thanks, ted
'03 Sedan 5a: BS/G, Prem, Aero/Body, Sport, Nav
Click here for mods
Old Nov 5, 2003 | 07:37 PM
G35Lin's Avatar
Multi-Spoked Mod
Re: How to remove lower dash
Well, there is a screw on the bottom left corner that is near the brake release(if you have auto). Once thats out, just put the panel from the left out first. THen you would have to disconnect the hose. I haven't figured out how to disconnect the parking brake because i think its going to be a pain to fit it back on.
THen for the CIg lighter area, ther are two screws to that. One below the steering wheel(from steering wheel look SE). THen there is one deep left of the cig light plate. ONce you got that, pull it off! There you go! Hope this helps!
If not, MSG me!
Old Nov 6, 2003 | 01:02 AM
SoCalTed's Avatar
It was easier to just pop out the cig lighter from it's bezel and then slip a small screwdriver to release it from the slot on the left side of the hole.
Disconnected the small 2-wire harness that feeds the lighted bezel of the cig lighter. Cut, slid on the heat shrink, spliced, soldered - then fed wires thru the cig hole, down and under the dash.
Pushed the cig lighter harness back on, and then popped the whole cig lighter back in.
now I have a red and black wire under the dash providing switched power!
Click here for mods
EasySausage
Sep 24, 2015 01:06 PM
neight
Interior
Sep 21, 2015 05:35 PM
Kicknshift
Sep 3, 2015 09:35 AM
pasjr1972
Sep 1, 2015 10:17 PM
brane123
Interior
Aug 23, 2015 06:55 AM
