Clock light not working...help
Old Aug 25, 2009 | 08:02 PM
chris12's Avatar
Originally Posted by zohdi
hi fellas
in case of this thread
Get the "30% brighter than regular Neo - Wedge LED Instrument Panel Bulbs," near the bottom of the page - http://autolumination.com/74.htm
can anyone just tell me wich tybe should i order for my 2003 g35 coupe .. there are 3 tybes with different sizes
please help ..
thanx
You answered your own question above. Get the 30% brighter neo wedge bulbs in either amber, white or blue.
Old Aug 25, 2009 | 09:09 PM
zohdi's Avatar
I know that man
but when i want to order they ask me wich tybe
there is tybe a led , tybe b led and tybe c led
every tybe had a different size
thats my question .. thnx
Old Aug 28, 2009 | 05:09 PM
Boostedef's Avatar
I know that man
sorry but its TYPE lol
Old Aug 28, 2009 | 07:59 PM
zohdi's Avatar
Angry
Cheak the site buddy
there is 3 tybes
i dont know wich one match the stock clock lamp size
when you want to add your order to cart
you should chose the tybe
please help
Old Aug 29, 2009 | 07:56 PM
chris12's Avatar
there is 3 tybes
please help
Read this thread: https://g35driver.com/forums/lightin...t-guide-2.html which is referenced on the first page of this thread.
I could answer your question now, but its good practice to read through the entire thread before you ask questions that have already been answered
Old Aug 29, 2009 | 09:33 PM
zohdi's Avatar
Ok Sir
Thank you
Old Sep 9, 2009 | 11:13 AM
StevenK's Avatar
Just wanted to thank Chris12 for the info in this thread, saved me a ton of time and money.
Old Sep 9, 2009 | 02:13 PM
chris12's Avatar
Glad I could help
To directly answer the question above get the:
Type B LED
10mm= 3/8"
Old Sep 9, 2009 | 02:23 PM
WTFisJUICE?'s Avatar
argh i just installed the new LED bulbs and the light is still out. I think the clock unit failed. Does anyone know how much these babies cost?
Old Sep 18, 2009 | 07:34 PM
StevenK's Avatar
Same, I just replaced the lights with LEDs from above and still no light
Old Dec 8, 2009 | 12:27 AM
Johno's Avatar
New bulbs gone bad
Anyone have any idea why the two dealer bulbs I just replaced in my clock would go out after about four days? The previous pair lasted six years, then went out at the same time so I'm guessing some electrical problem.
Old Dec 18, 2009 | 10:39 PM
MyG8u's Avatar
I replaced mine with the superbrightleds.com 30% brighter 4mm amber bulbs, direct plug and play, very easy install, see pic
Old Jan 6, 2010 | 11:35 AM
SRau's Avatar
I got the 30% brighter from superbrightleds.com. It took a little doing to get them in -- took a light twist from a needlenose to turn them into place -- but the install ~looked~ right. However, they do not illuminate. My guess is that they must not be making good contact with the board. Any suggestions from those who have been successful with the replacement? I see on a similar (older) thread that I'm not the only one to encounter problems.
Old Jan 6, 2010 | 01:40 PM
StevenK's Avatar
Correction, only one light didnt work. Now the 2nd one is flickering. Guess I'll go get some cream of wheat bulbs instead. What a waste of time and money.
Old Jan 6, 2010 | 05:36 PM
  #30
MyG8u's Avatar
The bulbs are reversible, as in they fit in the wrong way (positive vs. negative terminal). Turn them around and see if that helps.
