Clock Light Replacement - Guide
Old Sep 13, 2007 | 12:16 PM
elvisin3d's Avatar
Whats the best LED to install to add a super white or light blue tint to clock...This stock orange gots to go!
Old Sep 13, 2007 | 12:44 PM
Red_G35's Avatar
Originally Posted by cmthresher
go to superbrightleds.com they carry a led bulb that twist in and it fits perfectly.. no wiring required... EASY
link, please??!
Old Sep 15, 2007 | 06:11 PM
noooorb's Avatar
nm..........
Old Sep 15, 2007 | 08:34 PM
g35rcr's Avatar
Originally Posted by Wezbian
So my clock lights went out... I didnt know they were actual bulbs and not LEDs. Anyway the dealership took a look at it and charged me like $50 to tell me the bulbs were out. They were nice enough to offer to replace the bulbs for....$90!!!!!!!!!!!!!!!!!
I told them I could do it myself, how much for the bulb and socket? $15.95... for 2? NO FOR ONE BULB AND SOCKET.
So i bought one to make sure it was the bulbs out and decided to do a little DIY myself on replacing the second bulb.
Here is what you will need to do to replace it for $1.99
1. Remove the plastic dash around the clock. You need to pull it directly toward the seats NOT UP towards the windshield.
2. Unplug the car alarm LED
3. The clock is held in by 2 screws, unscrew them.
4. Unplug the wire connecting the clock
5. There are two grey or black circle sockets, take a screw driver and just twist them half a turn and they should come out.
6. There is a yellow...sock....over the bulb, gently take it off.
7. On the underside of the socket you need to take something like a needle and unwind the wire from around ther bottom of the socket.
8. Straighten out wires and pull the "grain of wheat" bulb out.
9. Go to fry's and get a "grain of wheat" bulb 12v or 14v, strip the wires to match the bulb you took out, and basically instert the new bulb in, put the little yellow sock thing back on it. Twist the wire around the socket like it was orginally on, and plug it back in.
I hope this helps anyone before they try and have the dealer do it or pay $15 for a single bulb.
or if you are cool with your tech and didnt make him do a bunch of free work without thanking him you can ask him for a bulb...my tech keeps all kind of spare parts in his work station. i tipped him when he installed my new clutch and flywheel when my trans got replaced, he never had any issues warrantying issues based on what i tell him
Old Nov 14, 2007 | 08:42 PM
hondojon's Avatar
LED Replacement
First, thanks to all of you for all the tips that you put out. I changed the brakes on my G35 because of the DIY tips in here. (Axxis Deluxe Advanced, which are very nice)
I needed to change the bulb in my '03 clock. I took your advice and found a LED light that works perfectly-turn and lock and you are done, no re-wiring.
autolumination is a company that sells these replacement bulbs. I emailed them on a Sunday and they replied within 1/2 hour. Here is what I ordered:
Type B
10mm= 3/8"
Neowedge
Item # Single Led Color: Super White
Lens: Type B Led
$2.99 USD
The direct link to this bulb is HERE
I went with the Super white though they have different colors to choose from. I kept the orange "socks" in case I want to match the rest of the dash. So far I like the white.
Chris and Tracy at AutoIllumination were unbelievably helpful, I highly recommend them!
Old Dec 5, 2007 | 07:20 PM
fuki's Avatar
What happens when you take the clock out and all that is there are two open holes? I guess it is time to go to the stealership again?
Old Dec 9, 2007 | 08:47 PM
mary6MT's Avatar
Awesome write up! THank you! SO easy!!!
Old Dec 10, 2007 | 11:32 AM
elvisin3d's Avatar
Did this over the weekend. It was a snap! Thanks
Old Jan 2, 2008 | 12:48 PM
shdowflare's Avatar
For those that don't want LED's, here's a link to the correct bulbs on Fry's website. I bought a pair of eBay that ended up not fitting correctly. Got these from Fry's and they work perfectly after you *carefully* strip off the wire shielding:
http://shop3.outpost.com/%7BTsEcXb-x...H:MAIN_RSLT_PG
Philmore 480 Grain of Wheat Bulb, 12V, 75mA (Frys.com part #: 2764843) $1.99
Old Feb 29, 2008 | 12:18 PM
Spedizzo's Avatar
anyone know any stores or large retailers that may carry this? I dont have a frys around me, I am located in NJ...
Old Mar 4, 2008 | 11:21 AM
jayjay1122's Avatar
Apparently we (g35driver) cleaned Frys out on these bulbs...
They are SOLD OUT!
There are some other places on the net that sell these. One place I found sells them in Clear, Amber, Green and Red but I think you have to by qty.100 which still only costs 15 bucks more than what the dealer charges for 1 bulb
Maybe someone can buy a 100 pack for $40 and sell them to our members???
Just a suggestion...
Old Mar 4, 2008 | 01:33 PM
Red_G35's Avatar
Type B
10mm= 3/8"
Neowedge
Lens: Type B Led
$2.99 USD
Wow, thanks... just ordered a pair!!
Old Mar 4, 2008 | 01:35 PM
crashnburn's Avatar
or you can just go to honda and get a bulb for a 98-02 accord clock or any dash light..they are the same exact and are a direct replacement and cost $3 each
Old Mar 17, 2008 | 11:28 AM
MixturePinoy's Avatar
For those of you who do not have a Frys near you, you can also go to radioshack
Old Mar 18, 2008 | 08:01 AM
  #30
FISA's Avatar
Thanks ordered a pair from AutoIllumination... looking forward to the installaton
