Clock Light Replacement - Guide
Old Mar 6, 2016 | 10:56 PM
  #196
Infiniti&chevys's Avatar
Clock bulb
Have anyone tried the Infiniti i30 or i35 clock bulbs do they work wit the Infiniti g35 clock or not?
Old Mar 8, 2016 | 01:26 PM
  #197
infinitidude's Avatar
Infiniti white-face clock conversion(clock from 2000 I30)
You can put the whole white face clock in if you choose, the I35 clock is silver faced. And yes all of the bulbs interchange
Old Mar 8, 2016 | 02:30 PM
  #198
Thanks I order the bulbs I will tried them n let ppl Kno if they work
Old Aug 26, 2018 | 11:03 AM
  #199
Cbst09's Avatar
I have a 2008 g35 sedan and my clock lights are burned out. Can anyone please tell me what bulb I should order? I see in most of the other posts that are older cars so i am not sure if it is the same bulb.thank you.
Old Sep 14, 2019 | 05:04 PM
  #200
LI-G35Driver's Avatar
Originally Posted by hondojon
First, thanks to all of you for all the tips that you put out. I changed the brakes on my G35 because of the DIY tips in here. (Axxis Deluxe Advanced, which are very nice)
I needed to change the bulb in my '03 clock. I took your advice and found a LED light that works perfectly-turn and lock and you are done, no re-wiring.
autolumination is a company that sells these replacement bulbs. I emailed them on a Sunday and they replied within 1/2 hour. Here is what I ordered:
Type B
10mm= 3/8"
Neowedge
Item # Single Led Color: Super White
Lens: Type B Led
$2.99 USD
The direct link to this bulb is HERE
I went with the Super white though they have different colors to choose from. I kept the orange "socks" in case I want to match the rest of the dash. So far I like the white.
Chris and Tracy at AutoIllumination were unbelievably helpful, I highly recommend them!
Just switched out the clock bulb while I had the dash torn apart doing the double din. Bulbs arrived today, fit perfect (thankfully since I lost one of the bases behind the radio). Just popped in and look fantastic. Got the bright white. I only wish all the instrument panels and HVAC controls light up this color.
Old May 10, 2023 | 09:53 PM
  #201
ㄴㅇㅇㄱ™ ninja's Avatar
Veteran: Navy
Veteran: Army
Kinetix V+,Z1UpperArms+HFC,FujitaIntake,Nismokit,BCCoils,HKSexh,G37rims,CFtrunk,nWpTB,SPCarms
You can actually order some overlays to place on top of your speedometer from addw1.com
File Type: mov
Hasanbaloch
Feb 29, 2024 08:45 PM
Luisgalvan33
Jul 19, 2018 08:16 PM
ClwMike
Jul 23, 2015 12:55 PM
Thunderaan
Jul 22, 2015 07:40 PM
