Clock Light Replacement - Guide
Old Nov 3, 2013 | 07:46 PM
  #181
vette87's Avatar
20 Year Member
Q40
Just wanted to say thanks for the write up. I just finished up and all is well.
Old Dec 2, 2013 | 11:57 AM
  #182
Insaniti's Avatar
Infiniti G35 Clock LED bulbs
Hi,
I replaced the clock lamps with White LEDs ordered from the ebay. Bulb type is T4 1/4 NW (Neo Wedge). Base is 10mm and bulb body 6mm.
Taking the panel and clock out was easy with instructions given here. Only problem was that there was no light after install. Polarity was wrong, so I had to take out the leds once more and rotate 180 degrees. I suggest to test the clock light before putting the top center trim back
Anyway, this is how they look like.
Old Dec 26, 2013 | 11:56 AM
  #183
Thruway's Avatar
Would anyone know what it means if the light went out simultaneously with the clock no longer working (totally dead)?
Thanks
Old Dec 26, 2013 | 12:00 PM
  #184
NFSP G35's Avatar
? = 2B || !2B
Clock lost power.
Either a fuse blew, or it got unplugged
Old Dec 26, 2013 | 12:07 PM
  #185
Thruway's Avatar
Originally Posted by NFSP G35
Clock lost power.
Is there a fuse just for the clock (and it's light)? I don't see anything else affected.
If so, would you know the fuse's location?
Old Dec 26, 2013 | 12:34 PM
  #186
NFSP G35's Avatar
? = 2B || !2B
I don't thinktthere's one just for the clock, but I don't know what it shares with.
You checked the fuse box in the footwell?
Old Jan 7, 2014 | 10:56 AM
  #187
Buhhraant's Avatar
I believe the clock light is linked with your running lights. When I blew my fuse for running lights the clock stopped working. Probably just unplugged...or crapped out
Time for i35 clock conversion!
Old Jan 8, 2014 | 11:36 AM
  #188
magnetism80's Avatar
Did I Blow a Fuse??
OK so this is a pretty easy thing to do, yet somehow I messed it up!! I had the clock out and replaced the grain o'wheat bulbs with the VLEDs. The light still didn't come on, so naturally, I went to pull it out to reverse the polarity. Like a lazy, dumb,_____ I did this BEFORE I unplugged the clock again (yes I know, I know, it was late, cold in my garage, and I wasn't thinking) Of course there was a nice little spark and some smoke as live current and a metal flathead screwdriver, aren't friends. Anyway.. NOW my dashboard dimmer function no longer works. All the lights (and climate/radio) come on and work fine, but they just don't darken when I turn the headlights on and this also means the dimmer won't work. Obviously the bright orange dashboard is annoying at night time. Did I blow a fuse? Now I can't see the clock at night AND the rest of the dash is too bright LOL. Interestingly enough, the clock still keeps time so I know it's getting power and not dead...
I checked a few fuses in the footwell box and none were obviously broken. Can anyone point me in the right direction of where I should look now before I start looking for wiring diagrams and tearing the car apart and the such? And before you guys say it....YES my lesson was learned!! LOL
Old Jan 8, 2014 | 12:35 PM
  #189
NFSP G35's Avatar
? = 2B || !2B
Check every single fuse... If you're really lucky, it'll just be one of them blown.
Honestly though, it sounds like you may have damaged the dimmer itself. I have no clue how one would fix that though
Old Jan 8, 2014 | 05:34 PM
  #190
Yeah I just noticed that my parking lights, tail lights and license plate lights are out too! These are all controlled by the same circuit so I'm sure it's a fuse now...Oh goodie wiring diagram time!! I'm just HOPING it's not one that's located in the IPDM. I had to find a wire to tap into before to hook up my DRLs... So I know for a fact it's a POA to work with since there is NO space and you have to pull the battery!! UGH.. this is some crap man. EASIEST thing to do and I fudged it up LOL and it's STILL cold as ball sacks in my garage and I STILL can't see the dang clock
Old Feb 11, 2014 | 05:36 PM
  #191
bmaldonado09's Avatar
Well I am new here and I was gifted a 2003 G35 Infiniti after I wrecked my truck. Anyways, the car is cosmetically great and mechanically is great as well (from what I can tell) but I have 150,000k on the car and I did notice that the clock light does not work. Anyways, I went about purchasing a pair of SMT High Power White Neo Wedge Base LED Light Bulbs T4 and I went about trying to install them and I thought that I had done so successfully but I am still not seeing any illumination and its driving me nuts. Any ideas as to what could cause this? On a second note, my coil on cylinder #5 was misfiring so I went ahead and replaced it, the gasket cover, and all 6 spark plugs with NGK Iridiums and I have noticed since doing so that I have a significant difference in gas mileage but it does seem like the car has more power? Any idea what could be causing this? I use Premium Gasoline and I just had an oil change/filter change early last week? What kind of oil should we be putting in these bad boys? I assumed they new.
Old Apr 20, 2014 | 04:26 PM
  #192
Gpowerr's Avatar
is there a different way to do it on a 08?
Old Sep 2, 2014 | 05:49 PM
  #193
kcmog35's Avatar
guys!!! thanks to this thread, i got my lights fixed up with the superwhite leds! thanks!!!
Old Sep 2, 2014 | 05:50 PM
  #194
kcmog35's Avatar
hey buddy. reverse the polarity on the lights by twisting the bulbs the other direction. you can look at the corner of the clock, with key or lights on, plug in the harness and see if youve fixed it.
Old Sep 17, 2014 | 12:58 PM
  #195
g35pearl20's Avatar
05 06 coupes .
So I had bought my leds and was ready to pop them in but when I pulled out my clock I saw that it didn't have a way to replace the bulbs that's when I looked inside and saw it was made of LEDS already. So I was pretty bummed out , does anyone know what size are the leds that are in those clocks and also how to take it part without removing the min and hour hand . ..
