Clock Light Replacement - Guide
Old Aug 27, 2010 | 01:08 AM
  #151
WhipWhitaker's Avatar
i know this is going off topic somewhat BUT
I was thinking of changing my amber LED's for red ones on the clock,
and i wanted to also change the lights on the AT shifter and the heated seat switches to red so that the red on the clock wouldn't look out of place..
i wanna do this on my 03 sedan
does anyone know what type of bulbs i need and where I could get them?
thanks to anyone for their help on this
Old Nov 28, 2010 | 01:16 AM
  #152
bryantp757's Avatar
I ordered these bulbs but when I went to install them into my 2005 G35 coupe. I found that they were LEDs on a circuit board. I really was hoping I could get rid of the orange leds but it looks like its near impossible.
Old Dec 18, 2010 | 01:14 PM
  #153
SilverMamba's Avatar
i tried the grain of wheat bulbs and had alot of trouble stripping them witout breaking them off on the bulb end...very fragile. off to the dealer it is!
Old Dec 18, 2010 | 01:18 PM
  #154
huan351's Avatar
Buy the LED that with the base. It is alot cheaper than the dealer.
Old Dec 18, 2010 | 01:23 PM
  #155
NFSP G35's Avatar
? = 2B || !2B
^+1000
Old Dec 18, 2010 | 01:56 PM
  #156
bryantp757's Avatar
Certain models do not have the grain of wheat bulbs...
Old Dec 22, 2010 | 03:03 AM
  #157
Boosted D.D.'s Avatar
Looks good
Old Feb 11, 2011 | 04:24 PM
  #158
Baliztik's Avatar
This is my next mod.
Old May 30, 2011 | 12:11 PM
  #159
naskomentata's Avatar
see video here.
10x
Old Jul 19, 2011 | 06:45 AM
  #160
Wilg35j's Avatar
Hey guysvi got superbrighled bulbs and they dont work i turned them around and still nothing so i guess i hace a bad clock, the little needle still works though so could it b a fuse
Old Sep 6, 2011 | 11:30 PM
  #161
pjgangsta's Avatar
G35X Revup
Do not buy from superlumination.com
I just bought 6 T4 Type B Japanese LED's Bulbs, and Neo Wedge 30% Brighter LED Bulbs for my clock bulb 03 g35 sedan. These are the same cheap LED bulbs that come from China. Many Chinese wholesalers or (dropshippers) have the same exact that are bought for 3 yuan chinese money which is approx $30 cents per BULB. The prices are considerably raised per unit/bulb which is robbery.
Pls keep in mind these Chinese Factory's have no quality control when these bulbs are produced.
Pls Consider buying bulbs that are significantly higher quality, and much safer at Autoillumination.com, superbrightleds.com, and ebay and get them for cheaper.
When sending e-mails to Tracy from superlumination to help out, she wasn't helpful and quickly canceled my order. Not only did she make accusations, she was extremely rude.
Old Oct 15, 2011 | 02:05 PM
  #162
Maple G's Avatar
I fixed my lights yesterday. No problems!! Take some time to strip the new bulbs...I have meat hooks and was able to do it so there's no reason it can't be done if you're patient.
$30 from the stealership isn't worth it. Not that I can't afford it, but I did it myself because of the ethics of the whole thing. Really pissed me off that they would gouge over a little bulb.
By the way. I'm in Toronto and bought my bulbs at The Source. They are NexxTech #2721141. These are 12V.
They were a little big to fit in the plastic base completely but they still work. Not too bright but bright enough to read the clock at night.
Old Nov 17, 2011 | 05:43 PM
  #163
SuperTrooper699's Avatar
bulb
i got my bulbs in today number 495 and they dont fit the socket they go into their too big.. Were yours?
Old Nov 17, 2011 | 05:58 PM
  #164
Rich@GRUBBS's Avatar
PREMIUM SPONSOR
hmmmm $16 would have gotten you two bulbs w/socket.....
Old Jan 8, 2012 | 05:03 AM
  #165
gupta88's Avatar
hey guys for anyone reading this, im a noobie and did it easily.
just watch the video above it has everything you need to know. the only part it doesnt is taking out the panel which i found easiest with a screwdriver near the top of the panel (near the windshield) loosening that and then pulling straight out towards you (not up) until the whole thing pops up.
then the bulb you want is the "30% brighter than regular Neo - Wedge LED Instrument Panel Bulbs Type B" on http://autolumination.com/74.htm. you can choose any color you want including stock amber. when you take out the old bulb by unscrewing, you will see this fits perfectly in its place with no work.
hope this helps!
