Clock Light Replacement - Guide
Old Apr 27, 2008 | 11:38 PM
  #46
Red_G35's Avatar
Might be polarized? try inserting turning the lights 180 degrees and see if they light up. Make sure you push them into place and turn them to lock in.
Also, make sure they are properly seated. I remember mine giving me a hard time when I put 'em in, had to use some pressure to turn them.
Old Apr 28, 2008 | 02:01 AM
  #47
305aznG35's Avatar
I did all that. I even took the bulb out of the socket, touched the end wire of the bulb and touch it against the circuit board, still the damn thing won't work.
To those that do not already know, the orange tint from the stock bulb is actually come from the orange plastic cover, peel that off and put it on ur clear bulb and I bet it'd match the rest of the car.
Old May 23, 2008 | 12:15 PM
  #48
en4cer's Avatar
Originally Posted by crashnburn
or you can just go to honda and get a bulb for a 98-02 accord clock or any dash light..they are the same exact and are a direct replacement and cost $3 each
+1 on the Honda dealership. Called the Infiniti dealership and they wanted $15 a bulb. Called Honda......$3.57 plus tax.
Old Aug 13, 2008 | 12:18 AM
  #49
xraycat's Avatar
If I check with Honda, do I get the base as well as the bulb? They didn't seem to sell the bulb on it's own and was charging $11 for a bulb and a base. I'm in Canada too so that may be the difference in price.
Old Oct 21, 2008 | 08:57 PM
  #50
netcbc's Avatar
http://g35ipod.com/installHW.php?skin=1
http://g35.ronchung.com/DIY%20Infini...iles/frame.htm
http://www.infinitihelp.com/diy/gcou..._procedure.htm
At 3:30
the autolumination.com is a direct fit, don't need use the old base.......
However the led bulb has a blueish tint
Old Nov 14, 2008 | 11:59 AM
  #51
Hanoon's Avatar
I still need help locating the bulbs to purchase.
Anylink from Ebay?
Old Nov 15, 2008 | 09:16 AM
  #52
NathanJax's Avatar
..... I WIN .....
Anylink from Ebay?
If you want the LEDs, go to http://autolumination.com/74.htm and scroll down about half way to the, "Order Neo Wedge Based LED Bulbs (shown above): $2.99 ea."
They have these colors... Blue, Super White, Red, Amber, Green, and UV. I purchased the Amber ones (you need 2) and they match the rest of the lights exactly.
You want to purchase the "Type B" LED
Old Nov 21, 2008 | 10:43 AM
  #53
Hanoon's Avatar
Thanks for the quick help
I have ordered these http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=200276073981
You think its same?
Old Dec 9, 2008 | 09:58 PM
  #54
17banners's Avatar
im actually having trouble pulling the plastic dash piece around the clock and a/c temp readout. advice?
I'm with you. I'm having a heck of a time getting the dash piece off? Any pointers? i can't get a good hold on it to pull it our.
Old Dec 9, 2008 | 11:37 PM
  #55
NathanJax's Avatar
..... I WIN .....
Flathead screwdriver and be patient....
Old Dec 15, 2008 | 08:47 AM
  #56
wtjessup's Avatar
Thank you for making this thread. I'm new to the forum and I went through the procedure yesterday to change my clock lights. Unfortunately when I got to the back of the clock I noticed that the entire light fixtures (bulb and base) were missing. I know I saw someone else who had the same experience, where would be the best place to purchase the whole fixtures as opposed to just the bulbs? Thank you guys for your help.
Old Dec 15, 2008 | 02:55 PM
  #57
waijai's Avatar
i.love.gold
Found this...cheap bulbs:
http://www.loystoys.com/loystoys/bulbs-and-leds.html
Old Dec 21, 2008 | 11:12 PM
  #58
chris12's Avatar
I think they are quite dim, not nearly as bright as stock.
I bought a set of the "30% brighter than regular Neo - Wedge LED Instrument Panel Bulbs." They are near the bottom of the page and are $3.49 instead of $2.99. Has anyone else tried these? http://autolumination.com/74.htm
Old Dec 28, 2008 | 12:00 AM
  #59
salt_fly's Avatar
Talking Removing interior trim
To remove the trim piece around the clock (and lots of other pieces too) go to
Harbor Freight Tools or Northern Tool and get a set of their trim removal tools. They are specially made plastic tools for removing trim pieces and they will not scratch up your car like screwdrivers or putty knives will. They come in a set of five or six tools for less than 10 bucks. Use the one with a gentle hook on the end and pull the trim around the clock straight out toward you. It pops right out.
Salt_fly
Old Mar 17, 2009 | 08:55 AM
  #60
chrischil's Avatar
maybe i should have went with those, instead of the "older" neo-wedge LEDs..cause i installed mine yesterday/last night and theyre not that bright at allllll...I was pretty disappointed..
