Help with taillights and interior lighting!
Old Dec 18, 2006 | 05:47 PM
Floyds_racing's Avatar
Angry Help with taillights and interior lighting!
I got in my car and none of the lights for the radio, navi, A/C or seat heater switchs where working and my tailights! I checked fuse inside kick panel and under the hood but all where good and check the Dimmer switch next to the VDC its not getting any power!! ANY HELP?
The interior lights and tailights are working as if the headlights are on the off position even if they are on!
Tyson
The radio works fine it acts like its in daytime mode all the time!!! here are a few quick pics!
Old Dec 18, 2006 | 06:16 PM
OK i just went outside a ran a wire from the positive term to the dimmer switch and there are 3 wires red w/blue red w/yellow and black If I run it to the redw/blue my tailights work but no interior lights at all!! its BLACK! If i run it to the red w/ yellow the taill lights dont work but the small light on the out side of the tails work but nothing changes with the interior lights
Old Dec 18, 2006 | 06:46 PM
4 Door Skyline's Avatar
have you done anything electrical lately?
Old Dec 18, 2006 | 07:06 PM
nope!
Old Dec 19, 2006 | 12:29 AM
accordfreak's Avatar
edit: did you check that fuse box to the left of the battery?
Old Dec 19, 2006 | 09:04 AM
I only know of two fuse boxes one driver side kick panel and one in front of battery and I checked both!
Old Dec 19, 2006 | 01:05 PM
g35rcr's Avatar
check your ipdm behind the battery...those black square plugs control things and it could have gone bad, bad news you have to replace the whole thing nissan/infiniti does not sell the modules alone...good news if you have warranty you are fine, if not maybe you were friendly to your service tech and he has a few sitting around...
Old Dec 19, 2006 | 02:09 PM
I will take the cover off today and check to see if I can find what you are talking about!
Old Dec 19, 2006 | 02:52 PM
YES that's the fuse box i'm talking about. not the one in front of the battery.
second picture of this thread. https://g35driver.com/forums/body-interior-exterior-lighting-diy/123555-diy-guide-kptechnology-fog-module-install.html
Old Dec 19, 2006 | 03:17 PM
second picture of this thread. https://g35driver.com/forums/showthread.php?t=123555
OK i will do that today when I get off!
Old Dec 19, 2006 | 05:21 PM
OK OK good news bad news
I found the tail lamp fuse it was bad!
and replaced it and the tail lights work now!!
when the headlights turn on my interior lights and guages go black!!!! I cant see shyt inside the car! Im thinking its the dimmer switch
ANYONE?
Old Dec 19, 2006 | 05:51 PM
twitch's Avatar
What happens when you adjust the dimmer switch? Anything?
Old Dec 19, 2006 | 09:17 PM
nothing at all!
Old Dec 31, 2006 | 06:15 PM
hipvspec's Avatar
nothing at all!
dude!! i have the same problem!!
Old Dec 31, 2006 | 07:30 PM
all it turned out to be was the dimmer switch was bad But they a 85 dollars!
mike730
Jan 12, 2018 04:25 PM
mjfenix
Aug 17, 2017 05:49 AM
zoop425
Mar 29, 2016 05:51 PM
linedr89
Aug 17, 2015 05:11 PM
Jadenkid22
Jul 14, 2015 12:33 AM
