Factory iPod Integration Successful...
Old 06-18-2008 | 02:59 PM
Glycerine's Avatar
Originally Posted by jtesensky
From what we have been given by Nissan regarding this kit, it WILL NOT work with the iPhone or iTouch...
It works with my iphone.
  #467
Old 06-19-2008 | 03:10 AM
humara's Avatar
Actually...
The '03-'06 G35 Sedan & the '03-'07 Coupe CAN skip songs through the steering wheel. You have to HOLD the skip/seek button up or down for 3 seconds in order to do this. This function does not work on the '07+ G35 Sedan.
I personally have not heard anyone have an issue with this except those who own a '07+ Sedan. The kit was tested and installed on a '05 Coupe and the functionality works. If the 3 second hold down DOES NOT work on the '03-'04 systems this is news to us. Can anyone confirm this for me so I can change our wording on the site?
and it also doesn't work very well scrolling through songs either on the 03-04. if i select artists and start going through the list, i can only get about 5 or 6 clicks in before it goes back to display xm. any work arounds for this? and also does the email for support form on everythingg35 not work?
  #468
Old 06-19-2008 | 11:57 AM
Doc_Yizz's Avatar
you just gotta be patient and scroll slowly. If you scroll rapidly, it will go to the XM display but will keep on scrolling, which is useful if you have lots of music.
  #469
Old 06-19-2008 | 10:42 PM
humara's Avatar
thanks for the 03 info
thanks for info that pertains specifically to the 03-04.
annoying about the slow button pushing, but at least i've finally figured out what this kit can and can NOT do on the 03. i'd say overall i would give this a 7 or 8. only that high because of the effort required to swap out to a new HU.
  #470
Old 06-20-2008 | 10:28 PM
humara's Avatar
my 03 stereo crashes if i try to advance past the last song on an album if i have random=album selected. need to reselect a new album, and it won't ever randomly select a new album. random=list works though.
  #471
Old 06-27-2008 | 12:34 AM
spinn's Avatar
Is there an Ipod interface that will work with the 2003 G35 steering wheel controls (volume/skip/back)? The USASPEC model says it only supports 2004 and up...
  #472
Old 06-27-2008 | 03:40 AM
jalilig35's Avatar
anyone notice with the ipod integration its alot clearer louder and more bass?? anyone have subs with the stock bose hu and the ipod integration??
  #473
Old 07-02-2008 | 06:55 PM
jalilig35's Avatar
no one??
  #474
Old 07-10-2008 | 07:28 PM
BolivianFuego's Avatar
Question on this kit with scrolling through albums, does that make it any easier? I sort my songs through albums instead of playlists.
  #475
Old 07-10-2008 | 11:36 PM
ImFree's Avatar
Got the factory, but can't get it working
I have an 05 coupe w/ Bose, pre-wired for SAT, but no SAT. Installed the factory ipod integration kit in the trunk, no problems. I hooked up my 5G ipod, it shows the "OK to Disconnect" and the ipod shows it's charging, but I can't switch the mode of the radio to SAT or iPOD (I only have the RADIO button on mine, and it toggles between FM1, FM2, and AM). Any suggestions? I guess I can check connections again, but am I missing something?
  #476
Old 07-11-2008 | 04:57 PM
ImFree's Avatar
Got it working... found a bent pin, but was able to carefully straighten it out. Working good now.
  #477
Old 07-13-2008 | 09:26 PM
infinus's Avatar
As a warning to anyone wanting to use this with an Iphone 3G
This will NOT charge your iphone 3G, it will only play the music!
  #478
Old 07-16-2008 | 04:20 PM
cwylie's Avatar
What happened to the pictures?
  #479
Old 07-17-2008 | 05:59 PM
WWarthen's Avatar
iPod Touch Working
In case it is useful to anyone, I have an iPod Touch with 2.0 firmware and it is working perfectly under the factory integration.
Last edited by WWarthen; 07-18-2008 at 11:51 AM. Reason: Clarified that I am using factory integration.
  #480
Old 08-02-2008 | 04:41 PM
dudenotbombs's Avatar
I have an 04 Sedan and cannot find the prewired sat cable, it is not just hanging there like in the instructions on everythingg35.com
Has anyone experienced this or is there somewhere I should be looking to find it???
Quick Reply: Factory iPod Integration Successful...
