Double Din-ANSWER!!!
Old Jan 5, 2004 | 01:55 AM
  #31
NYCGspot's Avatar
Re: Double Din-ANSWER!!!
how long does it approx. take to get the parts once ordered? I'm just trying to work out a timeline before I get all my parts installed.
Old Jan 5, 2004 | 08:53 PM
  #32
g35mt's Avatar
Once he order it, it should take less than a week for Yoshi to recieve the part. Afterward, it takes another 1 week to arrive to the US. So approx. 2 weeks after your place the order.
g35mt
Old Jan 5, 2004 | 09:33 PM
  #33
crashTestDummy's Avatar
Is Grubbs still looking into stocking the double din? Does anyone know the status on this?
DP G35 coupe/ AT / Prem graphite / Sport / Aero / Titanium 19 tint / 5 wire hyper-ground kit
San Diego, CA
Old Jan 7, 2004 | 01:23 AM
  #34
AznIceRckt's Avatar
hh-hh-hholy f*&$% sh!!... is that alpine f1 i see in a g35 coupe with factory navi and jdm conversion? sooooo nice ( i think the blue units are alpine f1, could me wrong tho )
regardless, props!
*** 2003 G35s 5a/t / Pearl White ***
~ Volk Racing / Dunlop / Tein / Hotchkis / Blitz / Hks / Greddy / A'pexi / Sparco / Nismo / Alpine / Mb Quart / Sony ~
Old Jan 7, 2004 | 10:06 AM
  #35
tig488's Avatar
i dont think its alpine at all, it might be, but i dont think alpine puts their logo in the middle of the faceplate, and isnt the F1 chrome faced, those look black, it still looks great tho.
03 BS/Graph 6MT Prem Cp
19" Gunny TE37 275/30 MichPSports
kg/mm springs
camber rods
injenCAI/SES
Alpine/JL/Stinger
2Din
Old Jan 7, 2004 | 11:40 AM
  #36
g35mt's Avatar
that display look like a panasonic head unit. I am just guessing base on the color of the display. I've seen on a VW because they use Panasonic equipment.
g35mt
Old Jan 13, 2004 | 11:14 PM
  #37
Philthy's Avatar
The Radio is a CDA-7990, with the controller from the PXA-H900 below it... (Alpine F#1 Status)
Phil Petracca
Old Jan 14, 2004 | 07:59 PM
  #38
g35mt's Avatar
dang...that is heavy crap man. PXA-h900 is the mother of all digital processor. Nice setup man...
g35mt
Old Jan 23, 2004 | 04:40 AM
  #39
ShikoKaon's Avatar
So...
Just to sum up all the required parts to do the upgrade:
a) Double Din Center Console
b) AC Control Panel
c) The bracket to mount the aftermarket "device"
d) The cover or pocket to cover extra hole (if needed)
e) The wiring harness for the speakers???
f) SWI-X from PAC (if you want to still use the steering wheel remote)
g)Antenna adapter???
h) Lots of patience...
Am i missing anything???
Where do i get the speakers wiring harness from?
What type and from where do i get the antenna adapter?
Do you also need a wiring harness fo the radio? or do we just snip away wires and look for the right one?
Thanks!
S.
Old Jan 24, 2004 | 02:33 AM
  #40
g35mt's Avatar
Conq uss Scosche NN03 for wiring harness.
Follow below thread to get the antena working.
https://g35driver.com/forums/showfla...view=&sb=&vc=1
Patience, you will need it. Scroll up more and read up on the dual climate button. Please be very patience removing the button.
In my case, i didn't have the wiring harness.
Hope that help.
g35mt
Old Jan 24, 2004 | 01:18 PM
  #41
ShikoKaon's Avatar
Hey g35mt, thanks!!! and yes that helps a lot!!!
One more question though...
Does anybody have the stock radio wiring diagram? or how did everybody find the right wires to hook up the aftermarket radio? just grabbed a multimeter and started looking for power, speakers, acc, etc, etc.???
Thanks!!!
S.
Old Jan 24, 2004 | 02:33 PM
  #42
g35mt's Avatar
I don't know why you would want to use stock speaker wire if you planning to upgrade. The power wire, yeah just use the multimeter. I think you should get the wiring harness, that way you don't need the multimeter plus easier too.
Also, make sure that when you remove the rear seat, don't start the car with the seat off. That can trigger the air bags light to go on. If you happen to forget, there is a thread here how to reset the light.
good luck and take pictures once you are done. Hey if you can, take the picture of the step u took to install the double din. Last time i did it, i didn't have the camera with me. I want to create a step by step documentation on how to install the Double din. This is so other member can use it.
g35mt
Old Jan 25, 2004 | 06:44 PM
  #43
ShikoKaon's Avatar
Thanks for the feedback/advice!
I'll most definitely try to take pictures so a little DIY manual can be done. =)
Thanks again.
S
Old Feb 22, 2004 | 12:35 AM
  #44
nuttyprof's Avatar
what is the SWI-X from PAC?
and just to get this straight, if i only want to connect a headunit (meaning i will have one blank hole), and i have no nav, i should get the AL710 right? not the AL700 or AL510, but the AL710 right right right?
G35S 6MT
Technosquare ECU
350Z Springs & Struts
6-wire ground kit
Old Feb 22, 2004 | 12:36 AM
  #45
nuttyprof's Avatar
oh yea, one more thing, if i were to go to Japan, where would I get these things? is there a way to order the items i need here in the US, and have them ready for pick-up or have them mailed to an address in Japan for me? much cheaper.
G35S 6MT
Technosquare ECU
6-wire ground kit
