Sound deadening stuff
Old Mar 16, 2007 | 02:13 AM
Drewer's Avatar
So I'm in the process of putting in my sound system with lotsa toys and I decided to forgo the dynamat and any other mat clone and went with this gooey poo instead. I took pictures of the first coat and already laid down a second. . .it seems to make the metal panels have a dull "thud" when tapped. Has anyone else used it?
-andrew
Attached Thumbnails Sound deadening stuff-hpim0687.jpg   Sound deadening stuff-hpim0688.jpg   Sound deadening stuff-hpim0689.jpg   Sound deadening stuff-hpim0690.jpg   Sound deadening stuff-hpim0691.jpg
Old Mar 16, 2007 | 08:01 AM
seddon's Avatar
Yeah I used the same stuff, I put 3-4 coats then I used the edead also make buy ed. That "gooey stuff" helped but then I had to use the edead now my truck and cabin are very quiet.
Old Mar 16, 2007 | 01:48 PM
gramdacious's Avatar
eDead is fricken' rad. I used it in 3 cars now. Best bang for the buck deadener out there IMO.
Old Mar 16, 2007 | 02:07 PM
redlude97's Avatar
you should fill the cavities in the trunk with expanding foam also, helps with the rigidity and deadening
Old Mar 16, 2007 | 02:32 PM
TheForgottenMan's Avatar
I have a question about the foam. Does the foam expire? Do you have to replace it in the future?
Old Mar 16, 2007 | 02:50 PM
izmir41500's Avatar
G35driver Addict
how may gallons are you using?
i also noticed your sig says "enginerd", are you a tbp member?
Old Mar 16, 2007 | 03:07 PM
Drewer's Avatar
I think the foam he's talking about is something like this? I think since it's a sealant foam, it doesn't ever "expire." It'd probably last longer than the car. I'll have to get some more of this stuff. It's STICK as H3LL! Don't get it on your fingers! (Or in your hair!)
@izmir41500: I'm using a gallon. 2 layers down in the rear seat area and trunk and I'm almost half way down into the gallon. No, I'm not part of tbp. What's tbp?
-andrew
Old Mar 16, 2007 | 03:20 PM
izmir41500's Avatar
G35driver Addict
tau beta pi. the engineering honor society. we sold t-shirts wtih enginerd on the front.
Old Mar 16, 2007 | 03:21 PM
CrazyRuskie's Avatar
^^ That foam will not expire. It will definately last longer than the car. It is used to weatherize homes in all the crevises such as around windows etc
Old Mar 16, 2007 | 05:01 PM
Drewer's Avatar
Ahh. . .gotcha. Haha! Now that you mention it, I do have the shirt that I bought from my tau beta pi friends at the University of Colorado. I'm an engineer, but wasn't greeky enough to be apart of any frat.
-andrew
Dallsinghjr1
Sep 17, 2023 11:25 AM
Marlin84
Apr 1, 2020 12:52 PM
Video Share
Jan 31, 2017 04:00 PM
dcsbh1
Oct 1, 2015 03:15 PM
