To good to be true! Complete Double Din for 158.99 and amp integration harness.
Old Apr 7, 2007 | 11:02 AM
Hi-TechG35's Avatar
Well I tried the harness. Itsatarp here is the link: http://www.installer.com/item/displa...php?it=99-7604
Old Apr 7, 2007 | 12:04 PM
filanj's Avatar
link doesn't work bro
Old Apr 7, 2007 | 05:40 PM
Hi-TechG35's Avatar
Here you go all fixed
http://www.installer.com/cars/by_car.php?carid=2914.
Sorry link must have gotten moved
Old Apr 7, 2007 | 10:07 PM
itsatarp's Avatar
I was refering to the guy who mentioned that $100 more you could get all oem parts.
Old Apr 8, 2007 | 02:00 AM
Sponger's Avatar
6MT Brembo Coupe
How'd the harness work out?
Old Apr 8, 2007 | 10:37 AM
Hi-TechG35's Avatar
^ I am still waiting for it to come in the mail. As soon as I get it and hook it up I will post the results. I figured already have a LOC spliced into the harness but just to make it easier for future installers let me try it out. Now we need someone to try out the double din for results.
Old Apr 8, 2007 | 05:41 PM
willthethrill's Avatar
any one order the DD kit?
Old Apr 8, 2007 | 11:33 PM
Pearl05G's Avatar
The harness works perfectly fine, Ive been using that one for a couple years now on dozens of installs. The alternative is a 70-7550 and solder on your own RCA leads.
The kit is from Metra, definately not OEM quality, but if your lookin to save a few bucks it'll work fine.
Old Apr 9, 2007 | 10:30 AM
Hi-TechG35's Avatar
^Thanks for the input. I would not purchase the double din but if I was looking to save a few dollars as you mentioned then I would. At least someone knows a little bit about the site and their products. The harness for the amp intergration is pretty much plug and play I assume.
Old Apr 9, 2007 | 10:46 AM
Pearl05G's Avatar
Thats correct, just your power/ant/amp/ill/ then plug in the RCAs. Still go for chassis ground though.
Old Apr 9, 2007 | 06:59 PM
Igor911's Avatar
I used that same harness prior to swapping out the bose speakers. It worked fine
Old Apr 9, 2007 | 11:01 PM
Extreme G's Avatar
Good job guys ...
Old May 1, 2007 | 05:35 PM
Hi-TechG35's Avatar
Forgot to give you guys an update because I've been so busy. Well I got the harness about 2 weeks ago and will be seeing if it is worth it this weekend. I will be putting fresh wires all throughout the car so I will keep you updated on the progress.
Old May 1, 2007 | 10:24 PM
G35MR2's Avatar
I just ordered this DD kit...I tried getting the JDM but it was all on backorder, and I really want to install my new HU. So should be here within the week, and lets all prey that the quality is good. (It's made by Metra)
Old May 1, 2007 | 10:37 PM
  #30
akachi's Avatar
will the harness work on 06-07??
