To good to be true! Complete Double Din for 158.99 and amp integration harness.
Old May 2, 2007 | 05:07 PM
  #46
Hi-TechG35's Avatar
Thats what the harness does. Straight plug and play and "Welllahhh" You have RCA plugs.
Originally Posted by brikkman
Well, I my thought process was as the same as hooking up your standard radio to a car. I figured the amp was intergrated and would pass through the standard harness. Is this not correct?
I guess I'm just trying to hook it up standard.
Old May 2, 2007 | 05:43 PM
  #47
NgoWay's Avatar
Originally Posted by G35MR2
Well You're almost there.
1) Run the power line back
2) find a suitable ground
3) Splice into the rear speaker line coming from the HU Before the AMP (Search wiring diagram)
4) If your AMP has "Line In" feature hook those wires up to the little harness provided
------Otherwise use a Line-out converter & Run RCA's to the AMP
5) Splice into the Remote wire (going into Factory Amp)
Sounds Kinda complicated but shouldnt take you more than an hour or so. Just search for the Bose Wiring Diagram.
Hope that was a help
I understand the the splicing of the wires and have seen the diagrams. It really doesn't look that difficult. What I'm wondering is, with this harness, does that make it so that you don't need to splice any wires anymore?
Old May 2, 2007 | 05:45 PM
  #48
NgoWay's Avatar
Ok well... I guess my question was already answered before I could finish posting.. thanks
Old May 3, 2007 | 02:22 AM
  #49
G35MR2's Avatar
Yeah Im sorry I deleted my post, after I realized your question. I apologize for that.
Old May 3, 2007 | 08:11 PM
  #50
coldcallman's Avatar
I there any sound quality with the harness.... I do not want to deal with the HU.....Also, does anyone know how to disconnest the locks and power windows? I got the panel off but, can not figure out how to unsnap them
Old May 3, 2007 | 09:22 PM
  #51
Hi-TechG35's Avatar
^You have to snap slide your fingers under the panel and pull them gently because there are clips holding the panel.
Old May 3, 2007 | 09:34 PM
  #52
I got that but the actual clips that go together for the locks and windows they come apart somehow
Old May 7, 2007 | 12:28 PM
  #53
Hi-TechG35's Avatar
Update
For those of you that tried to order the DD kit, Metra will be releasing at the end of the month. I found this out on Saturday from a local car audio shop here in Boston. When one gets to the store (scheduled sometime at the end of the month) the owner is going to give me a call to check it out I will take pics to update you guys as of to the quality of the kit.
Old May 7, 2007 | 05:21 PM
  #54
roblo's Avatar
I'll be eagerly waiting for your review. I have a A/C controller on backorder at Grubbs, now im thinking if i should cancel my order and wait for your review
Old May 7, 2007 | 05:33 PM
  #55
Hi-TechG35's Avatar
There are some metal rods that you just lift up from behind the locks. They are like joints and they just pop out. The window harness is also a harness with a clip on it.
I will be sure to send you a PM to let you know. Also how long has your A/C controller been on back order?
Old May 23, 2007 | 10:13 PM
  #56
DemonKid013's Avatar
Probably a stupid question. Where exactly does the harness plug in?
The extra plug near the amp?
Also how long did it take to recieve it?
Old May 24, 2007 | 10:03 AM
  #57
Hi-TechG35's Avatar
^These plugs go behind the radio and make the RCA ouputs for you from right there. I got my harnesses in about 4 days after I ordered them.
Old Jun 3, 2007 | 06:57 PM
  #58
ashadiow's Avatar
Any updates on pictures of this thing?
Old Jun 4, 2007 | 02:18 PM
  #59
Hi-TechG35's Avatar
Nothing yet. I am still waiting for the one that the shop ordered for a customer to come in.
Old Jun 4, 2007 | 03:20 PM
  #60
pedro83's Avatar
^^ boy that customer is taking his time!
