tvnav2go dead
Old May 1, 2007 | 08:16 PM
Neal376's Avatar
tvnav2go dead
I bought the tvnav2go and a fuse tap.
I grounded the wire coming out from the back of the tvnav2go harness and powered the tvnav2go unit with 12v from the fuse tap
worked for 2 weeks but not anymore. Today the weather shifted from really cold to really warm. but the tvnav2go just wasnt working even though it was receiving power and its LED light was on.
I plugged the OEM harness in and found out that the navigation by itself works fine
I checked all the connections and used a spare slot in the fuse box to supply power and re grounded the grounding wire on the harness - but it still is not working.
any ideas? could the grounding wire have gone bad?
Old May 1, 2007 | 08:21 PM
WaLLy's Avatar
have you e-mailed them yet?
Old May 1, 2007 | 08:52 PM
Neal376's Avatar
nah - i didnt have time to post it up until after their hours.
i will call em up tom - maybe its something stupid i forgot to do
Old May 2, 2007 | 05:41 PM
da mayor's Avatar
great customer service from dominic
Old May 4, 2007 | 02:53 PM
WaLLy's Avatar
Let us know how it went. Or if you found a solution to it. thanks!
Old May 4, 2007 | 11:40 PM
MoHaWk2003's Avatar
my nav to dvd switch in my TL was flipped for 1 whole day before i found out. i thought the unit went dead too, but fixed it just by flipping the switch back to navi mode.
your problem is probably worse, but just throwing in suggestions.
Old May 15, 2007 | 09:04 PM
Neal376's Avatar
yea i sent the unit back.
sucks - i dun know what happened
hey Dominic, did you get the unit yet, if so do you have any ideas why it went bad?
Old Jun 15, 2007 | 09:59 PM
Neal376's Avatar
the tvnav2go unit was replaced under warranty.
but the new unit has poor video quality. ive grounded the unit to the same locations as before...the quality gets better when you ground it but not as clear as the first unit i had. tons of those static lines
Old Jun 19, 2007 | 08:07 PM
Neal376's Avatar
Originally Posted by tvandnav2go
Hi Neal376
Did you ground the heavy black wire on the plug and play harness??? Is the video source also grounded to the car??? Did you try another video source??? Please call me at 718-763-7367 and we can go through some other options. You have a 1 year no questions asked on the unit so don't worry. We will get you fixed 1 way or the other.
Thanks Dominic www.TVandNav2Go.com
coolio
yea, everything is grounded. tv unit is static regardless of whether the video source is plugged in or not.
I'll call up later this week.
thanks mang
Old Jun 20, 2007 | 01:47 PM
digital1986's Avatar
x2.
chinee
Jun 10, 2024 07:48 PM
dcsbh1
Oct 1, 2015 03:15 PM
Jon81035
Sep 16, 2015 04:58 PM
eljefe7070g35
Sep 11, 2015 09:28 AM
