Weight with sound system.
Old May 5, 2007 | 12:30 AM
motiv3's Avatar
I am curious to find out how much weight I might gain by putting in, lets say a two 10" sub setup in my g coupe. After everything is installed, subs, and amps and other accessories how much weight will be added to the car roughly? Just wanted to know if it is a ridiculous amount or really not that much. Thanks.
Old May 5, 2007 | 12:39 AM
akachi's Avatar
about 10lbs for amp
20-25lbs for each sub
25-30lbs for the enclosure
Old May 8, 2007 | 10:58 AM
ron4row2's Avatar
Originally Posted by mx22o
about 10lbs for amp
This estimate may be low depending on the type of amp and subs you use. For example a JL 12W7 weighs 50lbs by itself. My guess is that you can count on 100-200 lbs.
Old May 8, 2007 | 11:01 AM
vaughn6mt's Avatar
= or > one fat chick
Old May 8, 2007 | 11:12 AM
b00stedjustin's Avatar
extra couple hundred pounds probably
Old May 9, 2007 | 02:20 PM
ltrrtl218's Avatar
^i doubt a couple hundred pounds. i mean assuming u dont get w7's and get some w3's or something similar at most i would say around 100 pounds. i have 2 12w1's and with them in a box i doubt it wiehgs more than 40-50 pounds. my alpine m1005 amp probably only weighs 15 pounds. maybe throw in 5 pounds for wiring. so lets say somewhere in the area of 60-70 pounds. if u get an amp for the speakers then ull probably add another 15 pounds. i used to have an alpine type x before it blew out and that thing alone weighed more than my 2 12's and the box put together.
Old May 9, 2007 | 02:32 PM
05BLACK6MT's Avatar
12w7=45
custom box=55
2 amps=35
cap=5
4gage wires cables + ++ + + =30
Old May 9, 2007 | 03:55 PM
digital1986's Avatar
lol but thats for a overpriced heavy sub
for a good estimate list everything you want to put in your car and for the enclosure use lightweight mdf wood like I did, it makes a HUGE difference
Old May 9, 2007 | 03:59 PM
Hi-TechG35's Avatar
An easy 50 - 100lbs. I've got 2 12W6V2's and 2 amps. When I took everything to clean the car I went for a spin and talk about big difference in power without the sytem.
Old May 9, 2007 | 04:07 PM
joe603's Avatar
Why not just add the components weight up? They all should have it in the included materials or on the boxes. If it's used stuff, you can find out the specifics online. Add about 20lbs for wire.
Old May 9, 2007 | 10:03 PM
motiv3's Avatar
LOL^ that made me laugh for a while.
Thanks a lot guys!
Old May 9, 2007 | 10:51 PM
motiv3's Avatar
Also, do you guys know if anyone has taken their back seats out and built a sound system in the back seat area?
Old May 9, 2007 | 11:04 PM
saitcho's Avatar
20 pounds of wire? yikes! i am running 0/1 gauge wire for power and even with my wiring rack i doubt all the wires i used combined weigh more than 10 lbs.
I think the most noticeable different in performance is going to be feeling like the back end is heavy due to the added weight. 100-200 lbs isnt as noticeable when its a passenger, but when its in the trunk it makes a more noticeable difference. I don't have the science to technically back that up but thats what I noticed when adding subs/amps/enclosure to my coupe.
Old May 10, 2007 | 01:24 AM
ttrank's Avatar
Grocery getter
I would say that between my 12W6 in 4080 box, 1000/1, 450/4, and wire I have 100lbs of extra weight.
Old May 10, 2007 | 09:33 AM
ron4row2's Avatar
I would recommend going with a fiberglass enclosure you will save a lot of weight vs. MDF. That stuff can get heavy.
Dallsinghjr1
Sep 17, 2023 11:25 AM
Marlin84
Apr 1, 2020 12:52 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
Video Share
Jan 31, 2017 04:00 PM
dcsbh1
Oct 1, 2015 03:15 PM
