Sound quality??
Old May 25, 2007 | 04:37 PM
GBoy's Avatar
Thanks for all you input guys, I know the best would be to add 2 amps
plus a sub, plus a enclosure but I need the trunk space, golf clubs etc...
I asked a friend how would my 2 channel amp work driving the front
components with Bose amp driving the rear doors and the woofer and he
said my Bose amp would heat up and eventually fail, is that right. I think
I can live with 2 amps screwed to the back seat inside the trunk or could one
go where the Bose baby amp is and one go under the passengers side seat, or one 5 channel AMP to run everthing but that same friend says that Bose
woofer would blow, so does that mean I would need another 8 inch
woofer to go in the back shelf. I guess I don't want an enclosure in the
trunk...
Old May 25, 2007 | 07:39 PM
Gilley's Avatar
If you don't want an enclosure in the trunk, you don't really have any options for a sub unless you want to go suztom and put a sub in the spare tire well. You could do a free air subin place of the factory 8 inch sub, but it's not going to perform very well.
4080 makes an unobtrusive enclosure for the passenger side of the trunk.
Old May 27, 2007 | 04:53 PM
GBoy's Avatar
Hey Sean
Is it true what my friend says in my previous post about the amp failing.
Old May 27, 2007 | 11:37 PM
Gilley's Avatar
Not if it's driving stock components for which it was designed to drive. It just won't sound any better.
Old May 31, 2007 | 01:22 AM
Vietnamezzboi's Avatar
Originally Posted by Gilley
Use the money you would spend on the new Momos and buy another amp to run the subs and maybe the rear speakers - meaning the side panel speakers. Don't bother with the 6x9's because those are the Bose so called "subwoofers." Many people don't even use rear speakers and like that. My rear speakers are faded way down compared to the front. If you have to use the rear speakers, you could run them - not the 6x9's - off of the Bose amp and use your existing 2 channel amp for the front Infinitys and your new sub amp for the sub(s).
i agreee with this guy! hes good
Dallsinghjr1
Sep 17, 2023 11:25 AM
Marlin84
Apr 1, 2020 12:52 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
Video Share
Jan 31, 2017 04:00 PM
dcsbh1
Oct 1, 2015 03:15 PM
