KP roll up - need up quick - outside fixing this crap
Old Jul 20, 2007 | 08:55 PM
Otacon132's Avatar
KP roll up - need help quick - outside fixing this crap
i got the thing in the mail today and i ahve been trying to hook this up for the past 2 hours, its rediculous - the instructions make it sound easy but i cant find the right wires apparantly. I have an 05 coupe and i tapped into the right wires behind the door panel right next to the speaker, into the harness that connects to the window controllers.
It doesnt work. I tried looking behind the speaker like it said too for a purple actuator wire but theres ntohing back there, there is a purple wire in the harness though.
any help please! (only thing i can think of is its not compatable with the 05......instructions say g35 up to 04 - but i dont think its that)
Old Jul 20, 2007 | 09:12 PM
4 Door Skyline's Avatar
this is from the KP website forums:
The wiring on the 05 is:
12VDC (KPtech Red) - White
Gnd (KPtech Black) - Black
RAP (KPtech Yellow) - Pink
Door Lock Actuator (KPtech Blue) - Purple
Door Lock Cylinder (KPtech Green) - Yellow
How are you checking the wires? The yellow wire (door lock cylinder) should read 5vdc until you turn the key in the cylinder to the 'LOCK' position. The door lock module needs to be plugged in for this to read on a meter.
The purple wire is behind the speaker, inside the door. It is a very short signal, and hard to read with a volt meter. Everytime you lock the door it will read 12vdc briefly.
The wire colors are out of the service manual, so I can't vouch for their accuracy. I've never installed a module on an 05, so verify before making connections!
Good luck,
_________________
Kevin Pierson
Old Jul 20, 2007 | 09:14 PM
good luck....let me know how it goes
Old Jul 20, 2007 | 09:26 PM
Otacon132's Avatar
i made the connections but it doesnt work =\ you hit lock twice am i right? its all connected and closed up i cant get it to go up, it goes down though
Old Jul 20, 2007 | 09:43 PM
Otacon132's Avatar
heres my connections im like positive their right, no idea why it wont work =\
Old Jul 20, 2007 | 10:07 PM
did u check if the windows and locks work after u made the connections?
im me, im on now (check ur pm for my aim screen name)
Old Jul 20, 2007 | 11:20 PM
Otacon132's Avatar
thanks for the help bro - just got done doing it, i took my time to solder everything nice and make sre connections are clean, and i found the purple wire......it is behind the speaker, in a plastic loom on the inner door's floor..
thanks for the help 4 door
Old Jul 20, 2007 | 11:37 PM
DHCrocks's Avatar
did you plug the window/door lock switches back in when you did the test? I think they need to be connected to work.
on mine you need to get the timing correct for the windows to go up. press too fast or too slow and it wont work. press, wait a second press in about 1 to 2 seconds they should start to go up. There's a slight delay.
Old Jul 20, 2007 | 11:39 PM
Otacon132's Avatar
yea i got it working, it was the purple wire that was connected wrong, i found the right wire
Old Jul 22, 2007 | 11:28 PM
KPierson's Avatar
Good to hear you found the wire. With the way its secured to the back of the door skin it can be hard to find.
Joe Gargano
Sep 18, 2015 11:17 AM
Mhacker
Sep 12, 2015 07:35 PM
twentyeggs
Sep 11, 2015 03:58 PM
JLee301
Sep 8, 2015 08:54 PM
UndyingDest
Drivetrain
Sep 7, 2015 12:49 AM
