a/c wont turn off and radio not working.
I had something similar to this happen to me while I was installing the new battery, what had happened was a fuze in that slim black box next to the battery compartment had blown, 15amp I believe, but once I had replaced it everything worked fine.
might not be the same but worth a check
radio
Originally Posted by efeezy619
just like the title says. It happened to my last g35 and it happened again to this one. I have a 04 g35 coupe and i was wondering.. If I get a Double DIN Kit and a new aftermarket headunit. Will My A/C and Navi start working? I know the Double DIN Kit comes with an A/C Controller but I dont know if this will fix my problem. Can someone please help?
Fixed link. http://x.infinitihelp.com/forum/loca....php?catid=180
On some model year 2003 G35 Sedans manufactured through August 21, 2002, the audio and temperature controls may not operate as expected. When using the audio equipment or the temperature controls, the unit may become inoperative. In some cases, this can be corrected by turning the ignition switch off and back on again. In other cases, the unit remains inoperative and requires service by an Infiniti technician. To prevent this condition, Infiniti has initiated a Voluntary Service Campaign to replace the audio finisher circuit board on these vehicles. Use Infiniti Net to confirm if a specific vehicle is affected by this service campaign (P3104).
Originally Posted by blanka98
I am having the same problem guys! Do you know if you can buy the circuit board somewhere online? I searched and no luck!
