Pioneer avic z1 owner, need a little help. Pics.
Old Sep 25, 2007 | 09:13 AM
tommyz9's Avatar
I will be installing the following at F1 Motorsport in North Hollywood next week. Before I take it there, just want to know anything else I might be missing.
1. HU pioneer avic z1
2. Ipod connector
3. blue tooth
4. steering wheel control
5. ac control and jdm frame
Anyone know where I can order the Black Trim that go outside the frame? If I want to watch dvd while driving, is there a part to that?
thanks in advance.
Attached Thumbnails Pioneer avic z1 owner, need a little help. Pics.-pioneer.jpg   Pioneer avic z1 owner, need a little help. Pics.-ipod.jpg   Pioneer avic z1 owner, need a little help. Pics.-bluetooth.jpg   Pioneer avic z1 owner, need a little help. Pics.-steering.jpg   Pioneer avic z1 owner, need a little help. Pics.-untitled.jpg
Old Sep 25, 2007 | 09:20 AM
OSKIRE's Avatar
how much did you spend for this setup?!?!
Old Sep 25, 2007 | 09:43 AM
lancer's Avatar
From what I remember, the Z1 is the easy one to hack, I believe there's a grounded-wire hack on avic411... looks good so long as you have the 3 requisite parts for the DD conversion.
good luck, don't screw it up
Old Sep 25, 2007 | 09:47 AM
Mitsuko's Avatar
usually to watch dvd's while driving u just ground the e-brake wire. the latest avic's tho have a built in gyro, so it'll sense you are moving and stop video. to bypass that, you have to unfold the sticker under the head unit that says "warranty void if removed" and then simply flick the switch.
negative of that is, of course, your warranty is void. I hear though there are bypass modules that are simple as plug and play, yet i have no experience witht that.
try the grounding wire first. if that doesn't work, decide whether you want to void your warranty, spend money on a bypass module, or live without driving w/ video.
Old Sep 25, 2007 | 09:59 AM
specialist's Avatar
well my z1 i just used the grounded-wire hack on avic411 it works i can't remeber to but i think i took out the tel phone mute out and move it to another spot on the plug. The grounding trick to you ebrake will not work
Old Sep 25, 2007 | 11:42 AM
tommyz9's Avatar
Guam671, I got the pioneer for $950 used. It came with the Ipod connector. Everything else is brand new. Total is around $1400 so far.
Old Sep 25, 2007 | 11:46 AM
docron1's Avatar
From: Centerburg, Ohio (the geographical center of the Buckeye State)
don't forget the wire harness (e.g. Scosche NN01) and the antenna adapter. The installer might have these already but will sell them to you at marked up cost.
doc
Old Sep 25, 2007 | 02:02 PM
JTG35's Avatar
You should just install it yourself. I saved $500 dollar by doing it myself
Old Sep 25, 2007 | 09:50 PM
OSKIRE's Avatar
wow...thanks...for the info...i've been wanting to change out my HU for DD setup....hope all goes well with the install!!
Old Sep 28, 2007 | 11:34 PM
DefJux921's Avatar
hey let us know how it went... post pics too... i've only been to f1 motorsports for springs but good experience and i'll go back.. i'm looking to get something similar.... what about the dual button?
Old Oct 19, 2007 | 12:59 PM
dannyboi2088's Avatar
there is a different way to by pass it.......someone told me theres a CD that you jsut put in and im guessing it is a program to by pass all of it.....but its for my z2 so i dont know if it would work with a z1 but currently right now im installing it in and ill let you know if the CD works or not
Old Oct 21, 2007 | 11:13 PM
krazynuttz23's Avatar
does the z1 or z2 have the capability to play videos from the ipod?
Old Oct 22, 2007 | 11:24 PM
does anyone have an answer to my question ^^. thanx!
Old Oct 22, 2007 | 11:30 PM
patman530's Avatar
no, unless you use a composite video out connection with the ipod, but you will not be able to control the ipod from the z1/z2. the limitation is not in the z1/z2, but in the pioneer ipod adapter...
Old Oct 22, 2007 | 11:52 PM
ah i c. thanx for that explanation. but with the avic-d3 you can play and control the videos from the ipod on the avic d3 correct?
