Using an inverter with an UDM
Old Oct 17, 2007 | 06:00 PM
g00's Avatar
g00
I don't have access to electrical sockets as i live in a high rise condo.
how well will this inverter work?
Amazon Amazon
Old Oct 17, 2007 | 06:36 PM
fais's Avatar
Says power output of the inverter is 160 watts of continuous power and 300 watts peak power output, couldn't find any specs on power requirements in watts on Porter Cable or UDM but it PC draws 4 A at 120 V so my guess would be P = V x I = 120 x 4 = 480 W? Not positive on that though lol
Old Oct 17, 2007 | 06:54 PM
redlude97's Avatar
Yep, at least a 500w invertor would be necessary, and possibly a 750w for the UDM. Automotive batteries are not meant to be discharged any significant amount without substantially shortening their lifetime. A did some rough calculations a while back, and you can probably only safely run the PC using the invertor for ~30 mins on a normal battery. A better option may be to purchase a dedicated deep cycle battery or two and wall charger, and build a cart for the battery to haul down for detailing, then recharge it with the wall charger in your home when needed
Old Oct 17, 2007 | 08:51 PM
g00's Avatar
g00
redlude, thanks for the tips.
What if i used the inverter with the car running? Or does the 30 minutes you mentioned take that into account?
Old Oct 17, 2007 | 10:38 PM
redlude97's Avatar
You could use it with the car running, but if you are talking about 2-3 hours of constant running, that is quite a waste of gas
Old Oct 18, 2007 | 01:02 AM
g00's Avatar
g00
i checked up on autopia and many forum members there echo your comments.
i think i'm going to try and find an electrical socket somewhere first
Old Oct 18, 2007 | 11:09 PM
Scrooge's Avatar
Just go to a friends house and ask if you can detail there
Joaquin03
Jan 9, 2008 07:04 PM
shdowflare
Aug 20, 2007 10:50 AM
g35driver05
Aug 4, 2005 10:28 PM
CKwik
Jun 24, 2005 10:39 PM
jakeup93
Feb 28, 2005 11:57 PM
