a/c blowing hot air at 61 degrees...
Old Feb 11, 2008 | 02:30 PM
k@osx71's Avatar
My a/c is weird... I recently turned the air down to 60 since it's been getting pretty warm here in Cali, and when I put the air up by 1 degree to 61 it automatically gets extremly hot! I don't use auto climate, and I have the vent closed. Is there a quick fix for this, something I can check myself and maybe just maybe attempt a fix? or is this straight dealer issue? I have about 2k miles left before factory warranty is up, and onto extended warranty so I would rather take it in before factory warranty ends. I've searched and saw that most people had problems with the a/c not working or malfunctioning but couldn't find anything with my problem...
Old Feb 11, 2008 | 03:52 PM
crashnburn's Avatar
there is a tube that is disconnected... think u might even be able to get to it from driver side under dash... just plug it back in. i read that one here or my350z.com... do a search.. also look in radio failures... thats where i found that info... im on my 4th bose headunit, which also messed up my a/c every time it went out
Old Nov 13, 2008 | 12:53 AM
AARONHL's Avatar
The left channel sound is cutting out and I have to hit the console to get it going again. Could the radio failure lead to the A/C problems?
Old Nov 13, 2008 | 07:36 AM
35bills's Avatar
Aaron,
Check your other thread that you started in the Sedan section..
Sounds like there is a loose connection. I doubt that the radio issue is connected with the HVAC problem.
https://g35driver.com/forums/audio-v...n-install.html
Let us know what happends!!!
Old Dec 3, 2009 | 07:13 PM
MrTheodore's Avatar
I just got the same issue and in Miami its a NO NO even in December.
k@osx71, have you been able to fix your issue and if not how much did the dealer rape you for?
hrdwirk1
Oct 2, 2015 06:34 PM
Learned Hand
Oct 1, 2015 09:02 AM
Jcruzg35
Sep 26, 2015 04:47 PM
vamarris
Sep 26, 2015 12:56 PM
master111
Sep 25, 2015 08:32 PM
