Problem with HVAC: Auto Temp control doesn't work
Old Feb 19, 2008 | 04:43 AM
DWeidman's Avatar
Hi All -
I am posting this because I am hoping there is an easy answer:
Replaced the Bose HU with a Double Din Kenwood 7100. The radio is perfect - the HVAC auto temp isn't working. I have two settings:
60 Degrees: Full COLD
61 Degrees (on up) - Full HOT. It is like it is missing the internal temp thermometer - so it assumes it is freezing and tries to heat the cabin as fast as possible...
The other buttons work: mode - ac - defrost - fan, etc.
My car came with the Dual Climate Control - but the replacement HVAC board didn't have that button on it...
Ideas?
Am I missing something easy - or do I replace the HVAC controls again (just a bad board???)
Thanks in advance guys:
-Daniel
PS> If this is the wrong section - feel free to move it. I have no idea where it should go...
Old Feb 19, 2008 | 05:48 AM
kyu1021's Avatar
undeneath the steering wheel, there is a panel that sits right above your knees. there is a sensor that you forgot to reconnect before you put it back together.
Old Feb 19, 2008 | 08:08 AM
Gilley's Avatar
^ Right. There is a tube and a white connector on the right side of that panel. You probably forgot about them.
Old Feb 19, 2008 | 02:09 PM
DWeidman's Avatar
Great - I will check this afternoon.
Thanks guys - will let you know if it works.
-Daniel
Old Feb 19, 2008 | 02:52 PM
DWeidman's Avatar
-Daniel
Yep... disconnected!
The installer apparently missed it - glad I have this forum to clean up after the professionals. ;-)
Thanks again, seriously, I appreciate it.
-Daniel
Old Nov 14, 2008 | 04:28 PM
AARONHL's Avatar
What's the cause if the in-cabin sensor is connected properly?
Old Jan 16, 2010 | 09:00 PM
G-Ticket's Avatar
I guess I have to bump this thread. I just had an Ipod connection and new front speakers installed. Noticed on the way home I have cold air at 60, hot at 61 and up. I looked for any unconnected wires and didn't see any. Did I need to remove any panels under the steering wheel or should it be right in front of me?
Thank you in advance. I actually had nightmares about having this work done, kept stressing something would get scratched or broke. Everything checked out fine before I left the shop...of course the one thing I didn't check isn't working.
Lisa
Old Jan 16, 2010 | 11:43 PM
G-Ticket's Avatar
Disregard my previous post...I found the DIY and fixed it.
Lisa
arora_g35
Apr 16, 2026 02:52 PM
newg37
Jul 26, 2015 09:32 AM
attarday
Jul 15, 2015 04:03 PM
