AVElectronics Install Problem
Old Apr 4, 2004 | 07:36 PM
CruiseX's Avatar
So i got everything installed and running nicely but I ran into a problem during the install and I cannot figure out how or why. After everything was all said and done, the airbag light on my dash is blinking. Anyone know why this could be or how to remedy it. I did only what i needed to get the system all set up. Any help appreciated. Thanks for all those people that helped out. Have a good one - ROB
Old Apr 4, 2004 | 08:56 PM
ikSardarG's Avatar
Re: AVElectronics Install Problem
Hmmm Not sure on this one... I would suggest you swing by your dealer and have the OBD system checked with thier tool. They can at least get the error code and go from there. The cost may be nominal.
From what I know about the Air Bag lights on most cars - if it is blinking or on in error, than your airbags will not function as needed. You should get this checked asap, just in case.
Navi-Conversion Kits at Discounted Pricing
*Authorized AV Electronic Dealer*
2003.5 Desert Platinum Sedan
Premium, Navi, xBox
Old Apr 4, 2004 | 09:19 PM
Meatshackle's Avatar
Deep Sea Moderator
If you disconnect the wire harness attached to the glove box (yellow) while the battery is still connected your airbag light will go on and it will cost you almost $100 to get the dealer to clear it. There was a post on how to clear it yourself. I think it was the same as the ECU reset (key on off, pump pedal, etc). Whenever you do any electrical work and plan on disconnecting anything it's a good idea to lower the windows and disconnect the negative on your battery.
Russ
Black 6MT Coupe
Jax, FL
PS2 and Headrest Monitors Thread
Old Apr 4, 2004 | 09:27 PM
SFLG35's Avatar
FGC President
no there is a diy on how to get it to go off. i did this when i was installin my lights and got it fixed. ill do a search for you in a few. its really easy.
Daniel
5ATc / DP / Premium / Aero / Clear Bra / 5% Tint - 30% Windshield / Ground Kit / Clear Corners / Shock Sensor / L.E.D. Hood Lights / Z - Tube / OEM Remote Window Up semi-fixed and installed
Old Apr 5, 2004 | 12:30 AM
CruiseX's Avatar
Well that is exactly what happened. I did remove that yellow clip from the glove box. 100 bucks is a little steep to get that taken care of. If you could hook my up with that diy I would greatly appreciate it. thanks again. Rob
Old Apr 5, 2004 | 07:24 AM
SFLG35's Avatar
FGC President
here it is. real simple to do. clearing airbag light
Daniel
Old Apr 5, 2004 | 07:38 AM
CruiseX's Avatar
so here is the catch with this. does clearing the air bag light just clear the light and avoid an airbag problem. or does this not matter because the blinking light is just a function of the install and the airbag would work anyways. thanks again for your help.
Rob
Old Apr 5, 2004 | 08:36 AM
SFLG35's Avatar
FGC President
the airbag will work. it just clears the code that caused the airbag light to start blinkin.
Daniel
chinee
Jun 10, 2024 07:48 PM
CrazyLogic219
Aug 13, 2015 06:40 PM
saskicker32
Aug 11, 2015 02:12 PM
chinee
Aug 8, 2015 10:11 AM
attarday
Jul 15, 2015 04:03 PM
