Weak Radio Reception with After Market Head Unit
Old Apr 19, 2008 | 10:13 AM
oooooooooooooq's Avatar
i tried searching and i cant find anything. so i made the title searchable.
I have a kenwood dnx7100 and the radio reception is horrible, should i
A) get a powered antenna
B) there is just no way to fix it and i have to live with it.
C) there are other ways to fix it besides a powered antenna.
thanks in advaced
-Justin
Old Apr 19, 2008 | 12:43 PM
Rocket1991's Avatar
how did you hook up the radio, what harness? you need to connect the power antenna lead to a switched power source.
Old Apr 19, 2008 | 03:29 PM
ClearBra_Guy's Avatar
Did you use the diversity antenna adaptor?
Old Apr 19, 2008 | 05:55 PM
Gilley's Avatar
Did you connect the power antenna lead when you installed the radio? It's my understanding that the antenna, which in in the rear window, has a booster that needs power.
Old Apr 19, 2008 | 06:08 PM
04G35NYC's Avatar
my friend also having this problem with his Kenwood.
Old Apr 19, 2008 | 06:31 PM
i dont have a powered antenna and i didnt install it my self, it was a metra antenna adapter.
Old Apr 19, 2008 | 07:39 PM
Gilley's Avatar
I know you don't have a power antenna. None of the cars do, but the power antenna lead needs to be connected to the stock harness. The antenna adapter is something different.
Old Apr 19, 2008 | 08:00 PM
so to correct this problem i should get a power antenna and connect it to the stock harness?
Old Apr 19, 2008 | 08:04 PM
You power up the antenna amplifier. It will be grn/wht or red/wht wire.
Old Apr 19, 2008 | 11:07 PM
Gilley's Avatar
No, you don't get a power antenna. You need to wire the power antenna turn on lead from your new radio to the correct wire on the wiring harness adapter (assuming that's what you used) labeled for the power antenna lead.
Old Apr 20, 2008 | 12:00 PM
alrite, the main problem is that i didnt install it myself, so when i take out the HU what should i look for, pictures would be great, and what exactly should i do.
also i brought it back to the place of install and they said everything was fine.
so could it be somthing different?
Old Apr 20, 2008 | 01:05 PM
G35ANSTA's Avatar
Dude, take it back to your installer and have him fix it! You should get what u paid for and there is noi reason why ur reception should be screwed up. There is plenty of people who hjave upgraded their HU with no reception issues.
Old Apr 20, 2008 | 01:07 PM
i did take it back, they said nothng was wrong. if everything is plugged in right then my question is, what could be wrong with it. i think it is just an inevitable problem.
Old Apr 20, 2008 | 01:27 PM
You could have several problems. The first one could be the installer. Does he know there is a antenna amplifier that needs to be powered up? You could also have a head unit with a weak tuner. Most aftermarket radios are never as good as the factory radios but should not be bad either.
There is a antenna signal wire that gets 12 volts that sits next to the constant power wire(yellow). This is the wire you will want to make sure is hooked up.
Old Nov 18, 2009 | 02:13 PM
fzr's Avatar
fzr
hmmm I am having the same problem and taking the deck out tomorrow, once I will see if I forgot to hook up the power antenna cable I will post it here...
AuAltima3.5
Audio/Video/Electronics
Sep 13, 2015 11:48 AM
AuAltima3.5
Sep 12, 2015 08:21 AM
gatorglaze
Sep 10, 2015 12:03 PM
Hawk196
Sep 10, 2015 10:37 AM
Machine Head
Sep 4, 2015 07:22 PM
