what type of sub does everyone have?
Old Apr 11, 2010 | 03:17 PM
  #61
nismike's Avatar
Got a 10" Bazooka DVC with a kenwood 900w x1 RMS. I like the tube because it hits hard, fits under the rear deck and it is pretty light weight. Drawbacks are its not as efficient on the really low frequencies and doesn't look as good as a custom enclosure.
Old Apr 11, 2010 | 04:32 PM
  #62
mrprofile855's Avatar
mine does the same thing, i used FatMat frm matmat.com i put it on everywhere i can. it does sound great inside but rattles when your outside
Old Apr 12, 2010 | 12:31 AM
  #63
Xet's Avatar
Xet
Originally Posted by elayman
+1.. I only push ~200watt rms I think on the jl10w3v2 and **** rattles like crazy.. I used some generic sound deadening mat and it still rattles (can be heard on the outside, but sounds fine on the inside), but definitely put some on the license plate
Hmm weird.. I'm running a 10w3 as well and if I remember correctly I'm running 300wrms on it. No probs with rattling plate ever though... although I don't really thump very often anymore.
Old Apr 12, 2010 | 01:18 AM
  #64
The Stimulation's Avatar
I'd check up on that FatMat after a few very hot days. It's been known to peel off because it's not butyl based, rather, it's asphalt based and cannot withstand temps as high as butyl can withstand.
Old Apr 12, 2010 | 01:20 AM
  #65
Try using an open cell foam. Deadener mat is aimed to reduce vibration whereas a pad that is open or closed celled will eliminate rattle. Open cell would probably be better that way it can compress when you screw the plate in.
Old Apr 12, 2010 | 01:22 AM
  #66
No setup currently installed, still in the process of doing my setup, but I'm debating whether or not I should use my JL 15w6 since it's new. I'm actually seeking to go with a pair of 15's and finding another 15w6 in the condition i need is too difficult so i'm opting for a pair of 18's if they fit.
I'd LOVE to run a pair of Image Dynamics IDW18's but they are $$$$. I might just go with Mach 5 IXL 18's or Fi IB 18's. Will be powered by a JBL GTO 1201.1.
Old Apr 13, 2010 | 12:33 AM
  #67
Xet's Avatar
Xet
2 18's are you crazy?? how the hell are you going to make those fit? much less fit with the optimum size box!! even sealed I don't think you have enough space.
oh wait see you are a sedan but still esp if you try to do ported I don't think that's enough room..
Old Apr 13, 2010 | 02:47 AM
  #68
Infinite baffle..use the trunk as an enclosure. A single 15 would fit no problem. 2 should as well, but I would get a ton more cone area with 2 18's. I'll have to remove the thick foam that is like 2" tall and build directly on that. I should have enough height and I would have to angle it a little. Width wise I should be fine too. If I can't fit a pair of 18's I'll do 2 15's for sure. My goal is to get as much low end reproduction as possible. I don't care too much about gettin very loud, it'll get plenty loud, but the things one will feel will be intense. A 16 Hz note will give the spine some shivers, hehe.
KruZZe
Feb 27, 2023 05:04 PM
Video Share
Jan 31, 2017 04:00 PM
Kelvin Style006
May 23, 2016 03:47 AM
G35VSHNG37
Sep 10, 2015 01:54 PM
