Air Conditioning issue after Double Din Install
Old Dec 9, 2008 | 04:43 PM
  #31
mmarookiejoe22's Avatar
I just installed a DD using the Metra kit. Everything works fine EXCEPT the friggin temp button - its stuck at 75. I didn't see the jumper thing before i had to put the whole interior back together. My question is more about the automatic climate control. Since I cannot change the temp, if I set it on auto will it blow hot air until the cabin is at the 75 degrees? OR will it, even on auto, blow out 75 degree air until I tear it all apart to see if Metra screwed me?
Old Dec 9, 2008 | 04:45 PM
  #32
NORTHTX, thanks for the info!!!
Old Jan 19, 2009 | 04:52 AM
  #33
RTBCoop's Avatar
I just installed the metra DD kit but my temperature won't change. I can press hotter and colder all day but the display keeps saying 63 deg. However, all the other buttons work. I checked all the connections and everything looks fine. anyone got any ideas? thanks!
Old Jan 19, 2009 | 08:27 AM
  #34
blazeplacid's Avatar
you need to take the entire kit out agian, a pain I know but it must be done.
once you have it off look on the back of the AC controls, there should be a black covering with 4 screws. When you remove this cover you will see the board for ac controls. In there you will see a jumper that is NOT supposda be there. It will be either in slot 1,2, or 3 remove it completly. Reinstall everything and you should be good
I had the exact same problem
Old Jan 29, 2009 | 11:30 PM
  #35
jpez179's Avatar
Exclamation
Originally Posted by docron1
ok...here are pictures that I just took!
this is the in-cabin sensor:
<a href="http://imageshack.us"><img src="http://img138.imageshack.us/img138/390/stickitkh5.jpg" border="0" alt="Image Hosted by ImageShack.us"/></a><br/><a href="http://g.imageshack.us/g.php?h=138&i=stickitkh5.jpg"><img src="http://img138.imageshack.us/img138/390/stickitkh5.b062487ba5.jpg" border="0"></a>
<a href="http://imageshack.us"><img src="http://img175.imageshack.us/img175/8452/incabinfilteroj5.jpg" border="0" alt="Image Hosted by ImageShack.us"/></a><br/><a href="http://g.imageshack.us/g.php?h=175&i=incabinfilteroj5.jpg"><img src="http://img175.imageshack.us/img175/8452/incabinfilteroj5.efbfe62080.jpg" border="0"></a>
<a href="http://imageshack.us"><img src="http://img166.imageshack.us/img166/2533/harnessig4.jpg" border="0" alt="Image Hosted by ImageShack.us"/></a><br/><a href="http://g.imageshack.us/g.php?h=166&i=harnessig4.jpg"><img src="http://img166.imageshack.us/img166/2533/harnessig4.0a769ef888.jpg" border="0"></a>
hope this helps!
doc
Doc or anybody,
I checked under my temp sensor as shown in your pics and It looks connected...any suggestions...
Old Jan 29, 2009 | 11:38 PM
  #36
AARONHL's Avatar
That's the problem my car is having and my in-cabin sensor is working correctly!
Old Jan 30, 2009 | 06:15 PM
  #37
jpez179's Avatar
Originally Posted by jpez179
Doc or anybody,
anyone??
Old Feb 25, 2009 | 10:48 PM
  #38
hottnes35's Avatar
I installed a dd in my o5 g35 coupe. I don't recall seeing those clips when i pulled my ac harness apart and I have the same problem with my ac. When it is at 60 it is cold but when I turn it to 61 it starts to get warm. I didnt even go under my steering for anything. If I dont have the clips you were talking about what should I do?
Old Feb 26, 2009 | 10:50 AM
  #39
hottnes35's Avatar
bump
Old Mar 10, 2009 | 03:54 PM
  #40
IgOtMyG's Avatar
Anyone have photos of these "jumpers?"
Old Apr 27, 2009 | 12:13 AM
  #41
PeterUbers's Avatar
Hey guys --
Don't fry the JDM a/c controller like i did -- make sure you remove the neg. terminal off the car battery ... that's how i fried my 1st a/c controller.... LOL
The symptoms were the following: none of the a/c controller buttons worked except the defroster button, none lit up, and the a/c was stuck on 75 with the air blowing towards the passengers' feet.
Old Jul 27, 2009 | 09:13 PM
  #42
AlexAZD's Avatar
Holy ****, I have been thinking about just going to the dealer until now. I think before I didn't see it because it was tucked into the side panel, hooked the hose and the sensor and boom... temp changes moderately from 60 to 90 now. Thanks!!!!!!!!!
Old Jul 29, 2009 | 09:44 PM
  #43
djekua's Avatar
I love you guys thats what was happening to me..the white plug was disconnected completly when ever anyone of you guys are in miami please call me up for some beers...thanks once again... Dj ekua
Old Aug 6, 2009 | 09:39 PM
  #44
Finally got the motivation to tear my car apart again (after MONTHS AND MONTHS) - FIXED!!! Thanks for the info everyone!!!
Old Jan 16, 2010 | 11:42 PM
  #45
G-Ticket's Avatar
I have to say I love you guys!! I just spent about 5 min. fixing the hvac problem, and I didn't even break a nail.
I know I would have been heading back to the stereo shop on Monday had I not found this thread.
This forum rocks!
Lisa
