speaker pops when i turn on my aftermarket headuni
Old Apr 25, 2004 | 03:50 AM
Eurog35's Avatar
i just installed my alpine headunit, but everytime i turn it on, it makes a pop noise to all my speakers including sub, does anyone know what the cause of this is? my gains are down too...
Old Apr 25, 2004 | 09:29 AM
chenga's Avatar
Re: speaker pops when i turn on my aftermarket hea
You need a power-on delay. Your amp and headunit are not turning on at the same time. Usually you need to delay the amplifier's turn-on.
Is it a really loud, bad pop? You could just deal with it if it's not that bad.
Old Apr 25, 2004 | 11:54 AM
djrobx's Avatar
Re: speaker pops when i turn on my aftermarket headuni
What is the remote wire on the amps connected to? If you just connect it to the accessory wire, the amps will often kick on before the head unit has powered up and you get a pop. Make sure you've connected it to the remote wire of the head unit.
Some of it depends on the amps and the heead unit too. I fought and fought with that on one of my old car stereos. I gave up and just got used to it. Then later I bought an EQ, and just by having the EQ in the loop, it completely solved the problem!
-- Rob
Old Apr 26, 2004 | 06:08 AM
g35audioman's Avatar
It could be a bad grounding point as well, but more likely the turn on delay is the culprit
Old Apr 26, 2004 | 11:00 AM
Eurog35's Avatar
my amp remote turn on wire is connected to my ignition i think, so even tho my radio isnt on, the amps are on...
this place messed up my damn install, sigh... so where should the blue wire from my amps connect to? the remote turn on wire from my alpine's power harness?
Old Apr 26, 2004 | 11:45 PM
djrobx's Avatar
Yes. As g35audioman said, your amps need a turn on delay. Usually the head unit's remote wire will create that delay for you.
-- Rob
hdmark
Apr 29, 2019 04:31 PM
mjfenix
Aug 17, 2017 05:49 AM
Jiggerjuice
Oct 5, 2015 02:33 PM
baker2795
Sep 2, 2015 06:00 PM
mdzukunft
Drivetrain
Aug 25, 2015 10:28 AM
