Does anyone know if the rear of the Bose Headunit has the plug for the Antenna? I'm looking to install the FM transmitter for the Alpine Changer, and wanted to know.
Thanks!
2004 G35s 5AT DG/Graphite/Premium/Huper Optik Tint
Thanks!
Yes it does but it's not the usual antenna jack and plug like your fm modulator may have . It's a two prong jack and plug so you'll need these two adpaters to hook up your modulator.
http://www.partsexpress.com/pe/pshow...=265-589&DID=7
http://www.partsexpress.com/pe/showd...number=265-590
I can understand the need for one of these, but why both of them?
you want the other end of the modulator to go back into the bose unit right? OK you've got the factory antenna cable with the funky 2prong jack which will go into the 40-NI10 which will allow the fm-modulator to hook up to one of the lines, the other side of the fm-modulator will go into the 40-NI20 that will come out as a 2prong jack to go back into the bose unit. Now hook together the other 2 cables on the adpaters for better reception. It's a diversity antenna. Hope this clears it up.
Yeah, I think it clarified things.. my other question is there any other place to get these cheaper?
Also, can you get to the back of the unit without taking the dash apart?
2004 G35s 5AT DG/Graphite/Premium/Huper Optik Tint<P ID="edit"><FONT class="small"><EM>Edited by tgenius on 05/03/04 09:48 AM.</EM></FONT></P>
G35driver.com Moderator
sounddomain.com
G35c-6MT-DG/Willow/HyperGround/BorlaExhaust/350Z-intake
Hmm you've got the sedan .. I think it's still the same as a coupe. ButI had to take apart 6 pieces to get to the back of the bose... the top piece where the clock is, a panel below the steering wheel, the glove box/panel, the panel below the bose unit that has the shifter and both panels that hold the cig lighter and aux power plugs. So pretty much most of the dash has to be opened. Search for 'taking dash apart'.
ramborami..what do I look for on sounddomain?
sounddomain has one the adpaters you need at a cheap price but don't carry the other side
http://www.sounddomain.com/sku/SCONDAB
Ok fellas, I found a place that carries BOTH cables for $10.95!!
http://www.audioinmotion.com/item.html;$sessionid$JTYI5PIAAAT1VTZENUEUTIWPERWRJPX0?PRID=1 354484
AgBullet.. thanks a million! I cancelled the order and bought it from them.. was $15 shipped (I had the order for $19, but hey, 4 bucks is 4 bucks!
LOL, cool man, good luck.
If you want tips on how to take apart the dash, checkout our FAQ/DIY section on the forums.
G35c-6MT-DG/Willow/HyperGround/BorlaExhaust/350Z-intake/AVIC-N1-double-din
btw, those two antenna adapters are sold locally at circuit city for I *think* ~$10 each. My CC had them at least.
In case you didn't want to wait for shipping.
2004 Twlight Blue/Willow 6mt Coupe.
Bel Vector 985 Hardwired.
Grounding Kit.
Splash Guards.
Carputer. (Thanks GOC,G35Pimp, and others for their ideas)
Grounding Kit.
Splash Guards.
