NAV thinks its in california
Old Aug 21, 2008 | 11:02 PM
bitsq's Avatar
like the title states the nav on my 03 g35 coupe thinks it's in California. While i am driving the arrow moves on the screen so something is working, maybe the position is just off or it cant connect to the satellite?
it has been like this since i got the car, it was a salvage vehicle and after the repair the nav hasn't worked right.
anyone have any ideas for trying to fix it?
Old Aug 22, 2008 | 01:02 PM
airdetail's Avatar
i bought my coupe used in washington state and it came from NY so since the disc wasnt for my region i had to get a new one. maybey that will help
Old Aug 22, 2008 | 01:08 PM
The Stimulation's Avatar
Although the disc isn't in the region it has maps for all the states.
To the OP, maybe try going to Settings>Navi and choose the option to reset default settings.
Old Aug 22, 2008 | 01:23 PM
bitsq's Avatar
hum... there isn't a setting to reset to default. And i just noticed that i cant adjust the clock on the screen it's staying at 00:00, hum maybe it's having a hard time connecting to the satellite or something?
Old Aug 22, 2008 | 01:26 PM
dieselaznrock's Avatar
might have to re-set the settings or update disc.
Old Aug 22, 2008 | 01:28 PM
Hmmm, that's odd...did you scroll down all the way, there are more options if you scroll down.
Here is a thread somewhat similar to yours, you can also try the 2nd method I posted.
https://g35driver.com/forums/audio-v...g-address.html
Old Aug 22, 2008 | 01:31 PM
2drwild's Avatar
My 03 navi did the same but put me in the ocean. I had to disconnect the battery and eject the nav disc weird but it worked.
Old Aug 23, 2008 | 01:22 PM
bitsq's Avatar
i just got a newer disk from the dealer and same problem, i upgraded from the 6.2 disk to the 6.4 disk... i'm now thinking that the car isn't getting a gps signal, is there anyway to test this?
Old Aug 23, 2008 | 04:21 PM
jimrockford's Avatar
Yes, when in the map view, look for a green or yellow satellite icon in the upper left hand corner. There is also a GPS page under Settings that shows whether you are receiving signals from any satellites.
As far as the location goes, you said the map moves while driving. Is it tracking your location correctly or showing you moving on streets in California? Or, is it just that the state defaults to California when setting a destination?
Old Aug 23, 2008 | 05:14 PM
bitsq's Avatar
i can see the satellite icon but there is no colour on it, also it says that the satellite is "out of range". So i'm assuming that there is something wrong with the actual gps transponder. I found out how to correct my location so i switched it from california to Toronto, Ontario.
Does anyone know how i can check or fix the gps receiver unit?
thanks for the help you guys have given me so far
Old Aug 23, 2008 | 05:22 PM
bitsq's Avatar
i'm thinking that it is possible that they forgot to connect the gps receiver when they fixed the car initially.. anyone know how i could check that?
Old Aug 25, 2008 | 05:53 PM
bitsq's Avatar
anyone?
Old Jan 26, 2009 | 11:31 PM
dwhorton's Avatar
You have to go to Settings - Navigation - Adjust Current Location and then use the map to reposition your location. If you have to go across several states as I did it's best to zoom all the way out. After 2 hours of looking at the manual and some trial and error I figured this out. So easy it's hard.
Old Jan 27, 2009 | 10:01 AM
bitsq's Avatar
i've tried that already, i set the location to my house and set it up perfectly but as soon as i shut the car off it goes right back to california
there must be something wrong with the actual gps unit, they might have forgot to reconnect it when the car was in peices.
where is the actual gps reciever and where does it connect?
any pictures would be much appreciated
i want to spend the least amount of time outside given that its about -20 outside right now :S
thanks for all your help
Old Jan 27, 2009 | 10:40 AM
05DGx's Avatar
Your nav dvd isn't for the software that's currently being used in your nav system. In other words, that new disk you got, or the one you got with your car is "too new" for the car, and as a result, the car wont load up the states.
It sucks, but if you downgrade, you should be okay. I think the Zenrin (the maker of our nav disks) has a list of what dvd's are appropriate for which model year car.
Try that before you go digging for your nav hardware.
