What Sub are you running in your 4080 box?
Old Oct 1, 2008 | 03:07 AM
  #31
bmpnride's Avatar
IDMAX10 in modded 4080 (driver side coupe)
Works very nice
https://g35driver.com/forums/audio-v...h-install.html
Old Oct 13, 2008 | 05:26 AM
  #32
Triple8Sol's Avatar
C'mon, there are so many more people with 4080 boxes. List up what sub/s you've installed now/previously whether it worked or not.
Old Oct 13, 2008 | 12:05 PM
  #33
lancer's Avatar
Originally Posted by g35man04
yes that is correct triple8sol....I cant remember if the grille would come off when bumping but I dont think so.
I know I've blown mine off a couple times
Doesn't happen that often.
Old Oct 13, 2008 | 12:07 PM
  #34
lancer's Avatar
Originally Posted by Triple8Sol
Well my 10" IDQ v.3 came in today, and got it installed. It's a very tight fit, so it will be a b*tch if I ever want to get it out. Grille fits too.
Is the v2 much different than the v3?
Just curious what part was a tight fit and whether this is driver's side or passenger's side.
Old Oct 13, 2008 | 05:03 PM
  #35
Triple8Sol's Avatar
The V3 is completely redesigned, and is much much better than the V2 in terms of output, efficiency, etc... I don't know the difference in terms of dimensions, although I do think the magnet/basket is larger?
Old Oct 14, 2008 | 07:05 PM
  #36
lancer's Avatar
Originally Posted by ttrank
G35 Sedan
Driver's Passenger side
JL 12W6
No mods
I also made a box for the driver's side to add a second one because there is no driver side 4080 for the sedan.
12w6 or 12w6v2?
Old Oct 14, 2008 | 11:37 PM
  #37
JZ's Avatar
JZ
G35 Coupe KY0
anyone ever retro a solobaric?
Old Oct 15, 2008 | 12:23 AM
  #38
lancer's Avatar
Sorry I just threw up in my mouth a little bit
Old Oct 26, 2008 | 12:21 AM
  #39
MikeGrote's Avatar
drivers side box with an icon. had to modify to fit it in there but its in there, but its tight. havent had it hooked up yet.
Old Nov 24, 2008 | 06:31 AM
  #40
duc817's Avatar
will the jl 12w7 fix in the 4080 box?
Old Nov 24, 2008 | 10:47 AM
  #41
lancer's Avatar
I'm gonna go with no, it won't fit, but even if it did, you would need about 3 times the airspace anyway.
Old Nov 24, 2008 | 10:50 AM
  #42
lancer's Avatar
Originally Posted by k67p67
G35 coupe
driver's side
Image Dynamics / IDMAX10 D2 v.3
needed to add 1.5" of MDF spacer rings to accommodate depth; 4080 grille is not usable without reglassing front of enclosure
I see what you did there-- I'll have to post up a pic of my IDQ 10 v3, I didn't use a spacer since the depth was OK, I just spent a couple hours with my crappy grinder trying not to ruin the box while making the cutout larger... for some reason the basket would rub...
but anyway, the grille fits on and that box is SEALED like a ****, added a little weatherstripping under the sub, there is 0 leakage. glass boxes are nice
Old Nov 12, 2009 | 03:54 AM
  #43
gizmo134's Avatar
hey i put a idmax 10d4 V3 in my 40080 (sedan)
i cut away a bit of the ring so the sub fit in, and added a 1/4" spacer for depth. granted i didnt have screws to screw all the holes in, it seemed to be making alot of noise. probably 2morrow im gonna pull the sub, put some weather stripping in, and try that. however, it made some like rattling noises, does anyone know about that? and i ran it for like 15 min, and came back and had a slight frying smell...
Old Nov 17, 2009 | 10:12 PM
  #44
mark1478's Avatar
hey guys. So the concensus is..with a 4080 sedan 10 box..an idmax or q sub wont fit in without mods?
Old Nov 18, 2009 | 06:01 PM
  #45
4080's Avatar
Originally Posted by MikeGrote
ok, thank you. so i guess im just gonna have to bite the bullet and buy it to see if it fits and if it doesnt then i guess im out some money? i emailed 4080 enclosures about a week ago and havent heard anything back.
looking at pictures, it looks very similar to the jl10w6v2 so i bet it will fit, i guess i could always get a spacer too
What email address do you have? Try ainslie@wave-electronics.net
THanks,
4080
