Garmin Nuvi 760 Install with pics
#31
Yep, SUmo Glue worked great, I had to hold it for an hour until it set, but then I just used painters tape to holde it in place over night until it realllly set, now the mount would break before it ever cam off, it really is that strong.
The door closes just fine...the navi unit just touches on the way down, but it's completely concealed when I leave the car, no need to take it out and put it away.
How does the closing door not catch on the navigation?
Can you shoot some pictures of inside the cubby of the mount?
I want to see how you mounted it if I may -
It looks marvelous.
Was removing all the panels and running the cable a pain in the butt?
How long did it take?
Thanks!
#32
#33
#34
I am doing this install today or tomorrow. I will try to take some pics. If you are curious about how it closes just go in you car and open and close it and you'll notice that with the angle in which it closes it shouldn't hit anything if it is mounted in the correct location.
What I am trying to understand is how to install the cradle and still manage to pop the navi on and off since the release mechanism is on the bottom of the cradle.
