Proper Way to break-in Speakers?
Old Jun 14, 2004 | 12:52 PM
afr0puff's Avatar
Supa Dupa Moderator
Does it just happen naturally with use, or is there a proper method?
http://www.anythingbox.net
Old Jun 14, 2004 | 04:42 PM
al503's Avatar
Re: Proper Way to break-in Speakers?
there's no real proper method. Just listen to it as you would normally unless that means full blast. After a couple days to a week (depending on how much you use them) they'll break-in.
Old Jun 17, 2004 | 01:47 AM
KPierson's Avatar
I've heard that there is a break in period. It usually involves playing 'pink noise' through the speakers for a while before they ever leave the factory. Some manufacturers do this, some don't
Kevin
www.KPtechnologies.net
AIM: KPiersonTec
04 DG Coupe / VDC Memory
OEM Remote Window up mod
Procharged / Crawford / TS
Old Jun 18, 2004 | 02:37 AM
g35audioman's Avatar
You could hook up your pair of speakers to a home stereo and play pink noise through them for about a day. That would get the job done real quick.
Typically, it takes about 10-20 hours to fully break in a speaker. Some manufacturers, such as Morel, suggest 40 hours of playing time.
Old Jun 18, 2004 | 10:37 AM
fluffydot's Avatar
what the heck is pink noise??
Old Jun 18, 2004 | 12:50 PM
djrobx's Avatar
You know when you turn a TV on without the cable connected and you hear that static whoosh? That's called white noise. Pink noise is similar but sloped heavier in towards the lower octaves to produce equal what should be flat (equal energy) accross all octaves. If you've got a good system you want to see a flat response when playing pink noise on an RTA.
Old Jun 18, 2004 | 06:14 PM
Gordgee's Avatar
Administrator
With home audio, it usually takes an average of 24 hours, moderate volume. Best to face the speakers close together and have them wired out of phase to reduce some of the irritating sound. Pink noise is great if you have a pink noise generator. If not, tune off-station on the radio. This is how I used to do it on home audiophile systems.
I'd follow the suggestion above if you're installing new speakers. Connect them to a home amp facing each other, out of phase, and let them run with pink noise or "off-station static" for a day.
If you crank the speakers too loud prior to proper break-in, they can sound harsh and non-musical forever![img]/w3timages/icons/tongue.gif[/img] So don't make the mistake of "seeing what they can do!" by being impatient.
<font color=blue>[i]GroundingGear™ Equipped </font color=blue>
Old Jun 19, 2004 | 02:37 AM
afr0puff's Avatar
Supa Dupa Moderator
f you crank the speakers too loud prior to proper break-in, they can sound harsh and non-musical forever! So don't make the mistake of "seeing what they can do!" by being impatient.
<hr></blockquote> LOL! So much for breaking them in. I just finished preliminary wiring and wanted to test everything. Keep in mind this is 2:30am. God damn thing must have been set to full blast! Gave me a heart-attack. Stupid thing wouldn't turn off. Volume **** wasn't working either. Then I quickly yanked the key out of the ignition. Neighbors must have loved that!
DEMoLITIoN
Audio/Video/Electronics
Apr 20, 2016 06:57 PM
MrIP35
Oct 25, 2015 11:13 PM
1Typhoon
Sep 25, 2015 08:45 PM
JustinMKN1
Sep 18, 2015 03:40 PM
Mikesta
Sep 10, 2015 05:14 PM
