Pioneer F90BT or Kenwood DNX5120?
Old 01-28-2009, 04:37 AM
im2slpy's Avatar
and what's the difference between 7120 and 5120? is it worth it?
Old 01-28-2009, 08:32 AM
TroysG's Avatar
Old 01-29-2009, 03:56 PM
jdmgee35's Avatar
Originally Posted by B L U E S L A T E
I just installed a 900BT (Premier model) for my friend a couple of weeks ago. I like the interface and everything, but the thing is sooooo slow! It was a huge disappointment for me. Also, it did not work with iPhone 3G. If I were you, I'd find a nav unit that's HDD based.
Weird, I have the same setup. Mine's fast and interfaces with my iphone 3g perfectly.
Old 01-29-2009, 04:49 PM
gwilli3272's Avatar
The firmware V1.0 is the slow one. If you have the F90BT and it is fast then you have V2.0 firmware installed on yours. On my wifes it was slow as molases going up in the winter until I installed the firmware update, now it is fast. No more slow load times, the bluetooth is ready to go before she even backs out of the drive.
Old 02-12-2009, 09:23 PM
JOEYD0730's Avatar
what is the advantage of having a higher pre-out voltage radio? what worjks best with the facotry bose amp and speakers 2v or 4v?
Old 02-13-2009, 07:35 AM
TroysG's Avatar
high pre out voltage means that when you go to add an aftermarket amp the amp won't have to work as hard to reproduce a high level of quality sound. that's the main thing with preout voltage.
it's a non factor if you're using factory equipment because you don't use them. unless you use the 7551 harness in which case you want at least 4v
Old 02-13-2009, 08:58 AM
caly2121's Avatar
Kenwood 7120, have it and love it, Garmin + ipod interface sold me on it, well worth the money.
Ninjay16
Audio/Video/Electronics
11
02-26-2018 06:14 PM
BfloG35
10-16-2015 05:22 PM
Frankieg35
10-07-2015 10:22 AM
1Typhoon
09-25-2015 08:45 PM
AuAltima3.5
09-13-2015 11:48 AM
Quick Reply: Pioneer F90BT or Kenwood DNX5120?
