PAX AUX PROBLEM
Old Jun 29, 2004 | 02:44 AM
G35Performance's Avatar
PAX AUX PROBLEM
Hi i just installed my Aux adap but for some reason i cannot get to the aux channel. I followed the instructions and read the DIY guide. Is there anything im missing? or do i have a defect...I have a 2003 G35 Sedan..
2003 G35 Sedan AT
Stillen Intake+Z-tube, True Dual Exhuast
Technosquare Ecu
7 wire Grounding Kit
Old Jun 29, 2004 | 11:07 AM
coasterlvr's Avatar
Re: PAC AUX PROBLEM
Is your car SAT ready? Did the place you buy it at ask you if you had a SAT button? You probably need to get a refund.
JT
JT Audio & Accessories
118 S. Loara Street
Anaheim, Ca. 92802
(714)817-8282<P ID="edit"><FONT class="small"><EM>Edited by coasterlvr on 06/29/04 11:44 AM.</EM></FONT></P>
Old Jun 30, 2004 | 12:58 AM
Re: PAC AUX PROBLEM
Thx for your help mine is not sat ready
2003 G35 Sedan AT
Crawford Plenum V5
Technosquare Ecu
Old Jun 30, 2004 | 01:03 AM
Re: PAC AUX PROBLEM
Will the PAC adapter work if i purchase the Sat Radio harness
2003 G35 Sedan AT
Crawford Plenum V5
Technosquare Ecu
Old Jun 30, 2004 | 02:16 AM
g4s's Avatar
g4s
Re: PAC AUX PROBLEM
wait i thought it shouldnt matter if the car is sat ready or not. the pac adapter just plugs in behind the stereo unit (where the factory sat harness would go and between the main power supply). you do not use the sat harness. unless your car is totally devoid of a sat button, then you should be good to go. nothing happens when you press the sat button?
hm, i guess im unfamiliar with the 03's....nm
Old Jun 30, 2004 | 04:04 AM
Re: PAC AUX PROBLEM
I have a Sedan made in 02 which does not come with the sat buttom. Can anyone tell me if getting the sat harness with make the adapter work? Since i might get sat radio later on.
2003 G35 Sedan AT
Crawford Plenum V5
Technosquare Ecu
Old Jul 1, 2004 | 12:14 PM
narkotic's Avatar
Re: PAC AUX PROBLEM
dude, if you don't have a SAT button there is no harness, there is no satellite, never. You will have to put a unit in that has Sat capabilities before you can use this aux adapter.
Old Jul 4, 2004 | 06:57 AM
BerkTechnology's Avatar
Re: PAC AUX PROBLEM
Ditto, if you do not have that "SAT" button, you can't use the PAC AAI-NIS. Plain and simple.
Old Jul 6, 2004 | 11:53 PM
Re: PAC AUX PROBLEM
Thx for the replys, guess ill have to use fm transmitter for now.
2003 G35 Sedan AT
Crawford Plenum V5
Technosquare Ecu
Old Jul 7, 2004 | 02:08 AM
djrobx's Avatar
Re: PAC AUX PROBLEM
The SAT connector can also be used to run an external CD changer. So it's possible to have the connection but no way to access it since the PAC emulates a SAT tuner instead of a changer (accessed by hitting the CD button again).
Old Jul 31, 2004 | 12:43 PM
Meatshackle's Avatar
Deep Sea Moderator
Re: PAC AUX PROBLEM
I just tried to install mine and I'm getting nothing. My car is SAT ready with a button and a plug in the back. I removed the factory sat plug, plugged in the pac plug. Removed the factory power harness, plugged the pac harness in and plugged the factory harness back into the other pac plug. I puress the sat button and I get "No SAT". Any ideas?? My car is ripped apart right now so I'd rather figure out I have a bad module before I put it all back together.
Russ
Black 6MT Coupe
Jax, FL
G35Driver.com Business Cards
Old Jul 31, 2004 | 03:45 PM
roblin's Avatar
Re: PAC AUX PROBLEM
Try this - turn key one more quarter turn so all dash light come on but don't start the engine - mine does that the first time it's installed after that it works fine.
Rob
Old Jul 31, 2004 | 07:13 PM
Deep Sea Moderator
Re: PAC AUX PROBLEM
After I posted here I made myself some lunch went back out and it worked fine. I guess it just needed to be reset or something like you were saying. Thanks for the tip. The sound is like night and day compared to the fm modulator I was running.
Russ
Black 6MT Coupe
Jax, FL
Thebaws11
Jul 2, 2021 11:36 AM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
wuzz-upp
Oct 3, 2015 04:21 PM
mattdg35
Sep 14, 2015 11:28 AM
Jnm07
Sep 5, 2015 01:16 AM
