Look at my pics...sub just arrived...need wiring help. THANKS!
Old Apr 16, 2009 | 09:53 PM
nchima's Avatar
Basically I have (1) Amp hooked up to this Alpine Type R sub...being that I have little knowledge on wiring, I don't want to mis-wire anything. I have a positive and negative twisted together and then (1) positive and (1) negative that split, I think...look at pics....and where do they go into the sub....thanks, sorry for being kind of vague...
Old Apr 17, 2009 | 05:07 PM
Drewer's Avatar
Those are some BLURRY pics!
It looks like you have a dual voice coil sub? If so, you'll need to either series or parallel the coils together. . .I guess there's other options, but you should really list all the stats of what amp you're using, what channels you're using, etc before you get any more specific help. . .
Old Apr 17, 2009 | 06:13 PM
Vrod-Mike's Avatar
Did you buy the dual 4 or the dual 2 ohm sub?
Old Apr 18, 2009 | 02:06 AM
nchima's Avatar
Just got it wired up, sounds good and hits good...I figure I have the wiring correct because I tried numerous combos...didn't work, did work and, finally I got it to sound clean.
DUAL 2 OHM
Old Apr 18, 2009 | 06:46 AM
Vrod-Mike's Avatar
The sub comes with a diagram of different wiring configurations to give you an idea of what the impedance will be so you don't fry your amp.
Old Apr 18, 2009 | 10:33 AM
blazeplacid's Avatar
if you give me amp model number and sub model number I can tell you exactly how to wire it
Old Apr 18, 2009 | 11:43 AM
PeterUbers's Avatar
careful, it may sound good .. but you'z may'z be'z fryin' you'z amp....
Old Apr 18, 2009 | 03:13 PM
nchima's Avatar
I jus had it checked by an installer, he says its good to go. Thanks.
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
prinny
Nov 22, 2015 11:07 PM
9tray turbo
Sep 29, 2015 10:22 PM
Jcruzg35
Sep 26, 2015 04:47 PM
