Use factory satellite antenna with aftermarket?
Old Sep 16, 2009 | 08:51 PM
Switch360's Avatar
This weekend I am installing all aftermarket audio:
HU
Amps
Speakers.
I have a Sirius Connect receiver to pair with my Pioneer HU.
On my old car it was a pain to string up the antenna for it on the roof.
Seeing as how my car already has a Sirius unit I figure I could
use the antenna form it at least, as I have read from these forums
you can NOT connect the factory Sirius receiver to an aftermarket head unit.
Instead of using the antenna pictured, is there anyway to use the factory one?
And if so, how?
Old Sep 17, 2009 | 09:16 AM
blazeplacid's Avatar
I dont think you can use the factory antenna
why not try to mount the antenna above the radio?
When you remove the radio there is a spot for the factory nav antenna.
That is where I put my aftermarket GPS antenna, works fine and have never lost signal
Old Sep 17, 2009 | 09:48 AM
TroysG's Avatar
you'd likely need an adapter - which are hard to find
Old Sep 18, 2009 | 12:42 AM
Pearl05G's Avatar
Yes you can absolutely use it. Aside from the plug which you will either have to change (the housing) or trim they both do the exact same thing - Provide signal.
Old Sep 18, 2009 | 08:46 AM
true they both provide signal but what if the factory is a round plug and the aftermarket is a square plug?
Old Sep 18, 2009 | 08:51 AM
Pearl05G's Avatar
The plug itself is not square, it is the 'housing' of the plug.
Old Sep 18, 2009 | 08:54 AM
yeah but id like to tell someone with 100% certainty that it will work before I tell them to trim up a factory part
not saying your wrong, but have you tried it before?
Old Sep 18, 2009 | 09:47 AM
Pearl05G's Avatar
Like I said originally it would be either a change or trim.
There are a few sites ( that escape me right now) that have various housings for these plugs if needed.
Yes, actually I have several times on different vehicles.
Old Sep 18, 2009 | 11:10 AM
WhosUrBuddiee's Avatar
An atenna is an antenna. Just cut off the old plug and splice on the new plug.
Old Sep 18, 2009 | 11:55 AM
TroysG's Avatar
my dad took the square housing off a sat radio antenna, and it worked but did not stay fastened. it became a nightmare keeping it running
Old Feb 22, 2010 | 08:22 PM
paulc's Avatar
Use my factory satellite antenna
Go tss-radio.com they have the adapter you need for most cars.
Old Feb 23, 2010 | 09:38 AM
ungarocd's Avatar
There should be a little locking pin in the plug that you can pick out and remove the housing. A few cable ties and a solid mount of the unit should keep the plug in securely.
jeffbdye
Jun 1, 2018 03:51 PM
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
DEMoLITIoN
Apr 20, 2016 06:57 PM
TurTLe*
Sep 29, 2015 01:43 PM
