Aftermarket Headunit w/ stock Bose
Radio problem solved! Just call crutchfield, get usa interface unit, done! I could write a book on this car, what a project! But it will all work out. I just want to add one thing off the audio note, I did some adjustment on the rear negative camber issue I have, made an adj with the factory limitations, not good. Got a set of Ibach camber arms, this weekends project or one of them,,lol, The minor adjustment I did make was a big help when going into one of my hot turns, the car felt much flatter with more of the rear tire contacting the road.
Remind yourself you made the right choice when the headunit fails completely and your $159 adapter is useless, and you spend another $300 on a repair, or $600 on a refurbished factory headunit.
Update: I installed the i-pod interface, works great! Sounds great! Two hours after work one night, not the worst job but a little tricky, there is a guy on you tube showing how to do it, and Crutchfield has very good directions, better than the manufacturer. Now onto the motor, and then find the dyno guy........
1Typhoon
09-25-2015 08:45 PM
