Tricking Factory Nav to change settings while driving?
Old Nov 17, 2009 | 09:52 AM
GamesOver's Avatar
Is there a way to bypass the factory nav and trick it so you can change stuff while driving? It sucks to have to pull over to change where you are going.
Old Nov 17, 2009 | 02:16 PM
pfarmer's Avatar
I agree it is locked down too far. As far as tricking the system to allow you to do what you want to do, well it is against the rules to discuss methods on how to do so.
Old Nov 17, 2009 | 02:51 PM
bigc's Avatar
Wings Nation
There is/was a DIY on here on how to do it. Basically, you find the VSS wire going to the Navigation Control Unit and splice in a switch. When you want to program the nav while moving, hit the switch - this cuts the signal that tells the nav that the car is moving. When you're done, hit the switch again and the nav updates to your current position.
KP Technology also sells a module that will do this for you (along with some other stuff).
Old Nov 17, 2009 | 03:17 PM
wreaks's Avatar
How about you just use the voice commands? Works for me. No need to stop or type, just speak.
Old Nov 17, 2009 | 04:12 PM
bigc's Avatar
Wings Nation
not all factory navs have that feature
Old Nov 18, 2009 | 09:37 AM
GamesOver's Avatar
I dont think mine has that. I will check into that.
GamesOver's Avatar
Thanks I will look into it.
Old Nov 18, 2009 | 09:50 AM
GamesOver's Avatar
The KP stuff looks real nice and the prices are not bad at all. I think I am going to go with that.
chinee
Jun 10, 2024 07:48 PM
Hasanbaloch
Feb 29, 2024 08:45 PM
EnCr1pt3d
Jul 8, 2019 02:48 PM
laksjd84
Steering & Suspension
16
Jul 12, 2017 12:22 AM
2014g35x
Jul 30, 2015 09:32 AM
