power, amp, sub help
hey guys alttile confused on how to wire everything up, i have-
BOX: 2 square sealed box
http://cgi.ebay.com/NISSAN-350Z-G35-10-03-UP-SUBWOOFER-SUB-SPEAKER-BOX_W0QQitemZ280447141741QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item414bf3c76d
SUB (2) kickers L710 1200watts/600rms
http://www.kicker.com/Solo-Baric_L7
AMP Orion 500.1
RMS Power Output (Watts x Channels) 175 x 1
Peak Power Output (Watts x Channels) 500 x 1
Power at 2 Ohms (Watts x Channels) 250 x 1
http://www.crutchfield.com/S-P7UBir0...=detailed_info
1) would this amp be strong enough to push both speaker, and how would i wire it?
2) can I just tap into the Bose amp and try to run rca without a LOC? will my amp convert it automatically?
3) what is the max lenght of the ground wire from the amp to the chasis 3ft?
4)with this amp will i blow anything like an alterator?
Thanks
AMP Orion 500.1
Thanks
Well, the first thing I see, which could be a big problem.
The box you bought (EBAY link you posted) has round holes while the speaker has a square configuration.
Secondly, those subs will likely be underpowered. If the amp puts out 250x1 (rms) into 2 ohms, then the max. each speaker will see is 125w when the speakers are rated for about 600W (rms)
Ground wire should be as short as possible, although not really required. You could run a ground wire all the way back to the battery if you wanted to. The only issue is the ground wire (return) would have a higher impedance than chassis, so you'll get more voltage drop.
This amp is not going to blow any alternator. Its a very low power amp.
Actually just found the PERFECT amp for you.
This ORION HCCA amp will be perfect your set-up. It will drive 800 Watts (RMS) into a 1 ohm load.
Just be warned, its not class-D, so its not very efficient. Going to require some huge power.
Hell, i may buy it. $245 BUY IT NOW is a STEAL for this amp.
http://cgi.ebay.com/Orion-HCCA-250-Competition-amplifer-Old-School-rare_W0QQitemZ190362599451QQcmdZViewItemQQptZCar_Amplifiers?hash=item2c527ec01b
And DON'T let the old age of these amps full you. These are some of the best power amps ever made. They sure don't make them like they used to!
and will splicing the wires from the back and converting to rca, would that be the right signal? or would i need a LOC
http://cgi.ebay.com/Orion-HCCA-250-C...item2c527ec01b
you can get a nine.1 from elemental designs for under $200
http://www.edesignaudio.com/product_...products_id=44
1200rms @ 1 ohm @ 12.5 volts
so roughtly 1400rms @14.4 volts
you are right!, i am trying to teach myself what the classes are and the ohms...i am doing alot of reading
DEMoLITIoN
Audio/Video/Electronics
Apr 20, 2016 06:57 PM
