GPS mount in cubby (where can i get this mount?)
I'm looking for a mount similar to the one in this install:
http://www.hurricanewilmacancun.com/...ps-install.pdf
The website that is mentioned in this install guide does not have the mounting kit anymore. Does anyone know where I can get one like it?
here's another one - RAM-HOL-GA22U:
http://www.gpscity.com/ram-mount-gar...hol-ga22u.html
looks a little lower profile than the RAM-A-238U. i wonder if either one would work.
same thing but comes with screws and cheaper. Also lists compatible garmin gps. I have the nuvi 660 so I still don't know if it will fit. I doubt garmin would change the ball size for the charging cradle.
yeah it definitely will fit.
check out this video:
http://www.gpscity.com/ram-mount-gar...be=nVA_6d04eI4
Also I read that the cradle does not ship with a RAM ball?? do you guys think this application will be sturdy enough to hold the unit in the cubby because the RAM-HOL-GA22U cradle is recommended for very low vibration and is meant to only hold up to 1lb.
anyone willing to try?
