how to setup key
1. close and lock all doors.
2. insert the master key in and out completely 6 times within 10 seconds. The hazards should flash twice if you did it correctly. if it didnt, then continue to insert the key in and out until it does. itll take multiple tries so dont give up.
3. insert the same key and turn it to the ACC position.
4. now press any button on the new key fob once. the hazards should flash which indicates the key fob is now programmed.
5. remove the key.
6. unlock the driver side door and then close the door. done.
