Which enclosure should I buy?
Old Feb 22, 2010 | 07:44 PM
UjaasG35's Avatar
Hey
I currently have the bose system in my 05 coupe w/ stock HU JL 500/1 amp and some 10inch JL sub in a random box.
I am about to pick up either 2 JL 10W6's or 2 JL 12W6's
I found some on ebay: http://shop.ebay.com/i.html?_nkw=g35...acat=0&bkBtn=1
or should i buy this one? http://www.tccustomz.com/inc/sdetail/1419
Also should I replace my head unit? or should i replace the bose speakers?
I am really looking for nice clean bass but also i would like to show off my subs if both of those are possible. I listen to mostly pop/hip-hop and rap
thanks!
Old Feb 25, 2010 | 11:39 AM
Buddi's Avatar
well you last sentence says it all... go for the custom enclosure... but if you have a bit more $$ to spare.. see if you can have an enclosure built to your taste...
Old Feb 25, 2010 | 11:54 AM
35Alive's Avatar
the tc customz enclosure looks great in the G and doesn't take up much trunk space. check out this thread. a guy on here put one in and says he loves it.
Old Feb 25, 2010 | 01:25 PM
UjaasG35's Avatar
yeah I found some guy who is going to builf it for $225.
I am picking up 2 10JLW6's hope my 500/1 should be good enough.
Now after I install those subs is there anyway to improve the sound quality w/o upgrading the Headunit?
im not sure if i need to buy a JL 300/4 and new speakers or just get the infinity kappas.
thanks
Old Feb 25, 2010 | 01:58 PM
Buddi's Avatar
thanks
Well all depends on how much bump you want.. the amp can definitely push the 2 10JLW6 subs with no problems..
now im not so familiar with the bose headunit...(how much amps the hu has to push each speaker) i would say .. install you subs.. see how the output is .. if the base is drowning the music.. then you can look into upgrading either your hu or speakers/ amp
Old Feb 25, 2010 | 02:03 PM
Wrathernaut's Avatar
Gentle Manne of Leisure
The Bose amp has pretty much nothing to push for each speaker. Maybe like 10w RMS and 30w to the sub.
I believe it to be the weakest (but not by much) part of the Bose system.
Old Feb 25, 2010 | 02:23 PM
Buddi's Avatar
^ see there you go ... now its up to you if you want to change the hu ( i guess to keep the stock look or not) or change everything... ( swap the hu and/or speakers and add the amp).. see your dealing with 500 watt amp to 2 10 subs.. going to be enuff but like i said all depends on how much bump you want....and if that bump will drown out the music to your likings..
1Typhoon
Sep 25, 2015 08:45 PM
Jpete
Sep 25, 2015 01:38 PM
JustinMKN1
Sep 18, 2015 03:40 PM
mamba24
Sep 15, 2015 10:37 PM
twentyeggs
Sep 11, 2015 03:58 PM
