Headunit works but speakers dont?
Old Feb 27, 2010 | 04:26 PM
Devinb30's Avatar
2004 g35 coupe, BOSE FACTORY SYSTEM.
Ok guys my headunit is working fine. But i dont hear no audio..?
At first when the problem started, all i had to do was turn off the car and put it back on and it worked fine.
Now it doesint work at all, I also hear a ticking noise from my front driver side speaker when everything stops working. (even with the radio off)
I do have a system installed in my car.(Subwoofer) And it works fine, even when my stock speakers are not working.
WTH IS GOING ON? I search and i cant find CRAP!
The damn double din dash kit is soo expensive its like hell with the G35s.
PLEASE ANY INPUT ON THIS WILL MAKE MY DAY BETTER!
Old Feb 27, 2010 | 04:28 PM
Wrathernaut's Avatar
Gentle Manne of Leisure
Your Bose amplifier is dead. Replace it with a good aftermarket, and you're good to go.
Old Feb 27, 2010 | 04:29 PM
You can go the really easy route and buy a used Bose coupe one from the marketplace, but it'll die the same eventually.
Old Feb 27, 2010 | 05:03 PM
Devinb30's Avatar
How positive are you the amp is gone? And if i replace it with a aftermarket amp how do i wire it? because every thing is plug and play with the factory one?
Old Feb 27, 2010 | 06:42 PM
S 854's Avatar
^ No one is going to be 100% right without being there with you and diagnosing it in person.
Wrathernaut is right in saying you're probably better off getting a new amp. I'd be of the mind to replace the craptastic front speakers too while you're at it, but that's just me. I'd say you could do this for less than $200, without labor charges, and you're only limited by your budget and time. If you could source another stock bose amp, just switching the amp out would be cost-effective
Look at the "How to Keep The Stock HU & Add Aftermarket Sound" sticky up there. A LOC would probably help you here too.
The link below is in very general terms, but the basic idea is there:
How To Install An Amp In A Car
Old Feb 27, 2010 | 06:52 PM
Devinb30's Avatar
GOT IT GUYS.. thanks.. Im just gunna replace my stock amp with another stock one. Bypassing my factory amp seems too confusing.
Old Feb 28, 2010 | 03:30 AM
Good luck with the longevity on your replacement. Just remember to get it from a coupe.
Old Mar 1, 2010 | 07:40 PM
Devinb30's Avatar
I have a Alpine 4 channel amp here at home to use .. But i dont kno how to wire it. i searched.. I just want to know if i use the speaker wires front the harness that gos to the factory amp... And where do i run RCA's From?
arora_g35
Apr 16, 2026 02:52 PM
mjfenix
Aug 17, 2017 05:49 AM
carid
Group Buys-Vendor
Aug 7, 2015 12:17 PM
attarday
Jul 15, 2015 04:03 PM
