JL 12w7 and 500/1
Old Feb 28, 2010 | 10:04 PM
UjaasG35's Avatar
JL 12w7 and 500/1
Just tested it out in my car. I need to get a custom enclosure b/c it won't fit my trunk.
1) Any1 know how if by taking out the spare I can get it properly mounted and fitted in my car? its lik 15-16" tall
2) Any1 running the same setup? Can you tell me the settings, I don't feel like getting a voltmeter and stuff
3) BOSE SUCKS! What should I replace the front two speakers with and which amp should I use to power it? Please a recommend a cheaper amp that I prolly buy used cuz i just spent $400 on the w7 + enclosure!
Thanks!
EDIT ********I DO NOT WANT TO BUY a 1000/1 AT THE MOMENT! THE 500/1 is perfectly fine! the 500/1 runs abt 700 while the optimal performance for the 12w7 is around 700. check the site! http://mobile.jlaudio.com/products_s...es_id=9*******
Old Feb 28, 2010 | 10:15 PM
Frankieg35's Avatar
W7 needs 1,000 watt amp.. Im selling 2 extant amps.. 1,000x1 and 604 4 channel.. pm me if interested.. Im in Jersey also
Old Feb 28, 2010 | 10:16 PM
JUM3's Avatar
i think those w7's will need a little more than 500 watts. their RMS is 1000 or something.
Old Feb 28, 2010 | 10:17 PM
UjaasG35's Avatar
no thanks. the 1000/1 only adds lik 2-3%. not worth the upgrade.
Old Feb 28, 2010 | 10:18 PM
Dubi2087's Avatar
That sub is being wwaaayyyyyyyyyyyy under powered get yourself a 1000/1.
Old Feb 28, 2010 | 10:28 PM
Frankieg35's Avatar
Thats why i told him to buy my 1,000 lol.. i got a 500 powering my 10w6.. 1,000 is needed to power the w7.. I think its on JL's website..
Old Feb 28, 2010 | 10:38 PM
UjaasG35's Avatar
Originally Posted by al503
good advice from 4080 about the cap. Skip it.
In terms of the electrical system, it won't handle a 1000/1 without mods. The 1000/1 has a 120 amp fuse IIRC. Your stock alternator is rated at 110 amps. I had my alt tested and it put out around 126 amps. Your's may be stronger or weaker but it'll be a minimum of 110 amps. Therefore, if the alt was just powering the amp, it will probably fall short. To compound the problem, your alt has to power the rest of your car.
The last time I looked into an upgraded alt, no one made one for the G. You may be able to have your's rewound but it only gives you more power up in the rev range and it'll suffer at lower rpms in most cases.
Have you thought of a 500/1 to power it instead? With 500 watts, you'll get around ~92% of a 12w7's potential. With a 1000/1, you'll only get around 95-96%. The extra drain is not worth it IMO.
https://g35driver.com/forums/audio-v...000-1-a-2.html
Old Mar 1, 2010 | 09:46 AM
mckma's Avatar
what size is that box , i just put a 12"prowedge in my g35 c ,
Originally Posted by UjaasG35
http://www.youtube.com/watch?v=biar88ZViQM
Thanks!
Old Mar 1, 2010 | 11:24 AM
UjaasG35's Avatar
15width*
16height
24length
how'd u manage to fit it in?
Old Mar 1, 2010 | 11:48 AM
mckma's Avatar
sheell fit ,but you got to take those two plastic things out, the covers that go around the tire , and the spare tire holder on the floor cut it out ,let me know whats up
15width*
16height
24length
Old Mar 1, 2010 | 11:59 AM
mckma's Avatar
you could cut those plastic things right in front the speaker box use a fine tooth saw to make a clean cut ,so u can put it back if u sale the car
Old Mar 1, 2010 | 12:26 PM
UjaasG35's Avatar
Will try soon. Thanks. Btw do u have ne pics? Is it stable?
Old Mar 1, 2010 | 12:37 PM
mckma's Avatar
yeah dude been doing install all my life not at some store but as a hobby just love this sh@% ,i added a post " 12 w7 prowedge--working on the pics and instructions right now right now oh p.s. the tire will fit , check out the post, when done
Old Mar 1, 2010 | 04:49 PM
The Stimulation's Avatar
If it was me, I'd throw TWO 1000/1's to the W7...then again I'm a bit crazy, whats new...
As for an amp for the fronts, here's a good buy:
http://cgi.ebay.com/CERWIN-VEGA-EXL-400-4-400W-4-CH-AMPLIFIER-NEW-EXL400_W0QQitemZ300402079567QQcmdZViewItemQQptZCar_Amplifiers?hash=item45f15bf74f
broke_as_ajoke
Nov 6, 2015 11:49 PM
ASUG
Jul 10, 2004 03:49 PM
gone
Jun 1, 2004 10:48 PM
wickedel
Apr 15, 2004 02:32 PM
