Filling the Gap on the JDM DD Kit and getting it flush
So I'm going to put in either a Z110BT or wait for the X920BT - I have read every thread on here about filling the gap around the edges for the JDM kit.
I'm leaning towards waiting for the X920BT because it isn't motorized and I can re-mount it flush to the finisher since the screen doesn't move. My question is - what is the best way to fill in the gap? I found a Nissan 350z scoshe trim ring - is this the one I use for the G?
I would perfer to have something that fits totally flush and perfectly fills the gap.
Need help guys - anyone have experience with this?
I think the most common piece used is just a generic Scosche trim ring, not sure if that differs from the 350Z ring at all.
If you need a slightly thicker trim ring, the Metra 99-9999 might be the way to go, but you will have to use a Dremel to get the best fit. I used it to inset my Pioneer F90BT slightly.
https://g35driver.com/forums/audio-v...ll-w-pics.html
It's just a matter of whether you cut to fill the gap inside the ring or from behind like I did.
Others have done the more flush look with just the Scosche generic trim ring:
https://g35driver.com/forums/audio-v...cs-inside.html
CHI-TOWNG35
Audio/Video/Electronics
Aug 19, 2015 11:47 AM
