amp bypass help
Old Mar 25, 2010 | 03:41 PM
spellcaster's Avatar
amp bypass help
Hi, <?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
<o></o>
I bought a harness, the Nissan Bose harness, does it go behind the head unit? i was thinking it would fit before it goes in the amp. <o></o>
<o></o>
So first thanks you for sharing any info, as your help is greatly appreciated. <o></o>
<o></o>
Now My question,<o></o>
<o></o>
I need to take out the 4 channel out and remote power on out from the back of the car (the trunk), to feed to my 4 channel T3-1000watts amp.<o></o>
<o></o>
How do I go about it, and bypass the amp, keep the stock head unit, and the stock wiring and not get a full new wire to the back. <o></o>
<o></o>
The next part would be to get the power to the speakers from the stock wires that are already there. <o></o>
<o></o>
Please let me know which wires to splice from which connectors, to feed the speakers once I am doing getting the signal from the head unit directly to my new amp.<o></o>
<o></o>
About my setup :-<o></o>
<o></o>
I have one 1000 watts 4 channel amp, and 250.1 mono amp for the rear Bose subs (6x9s)<o></o>
Again thank you for reading and helping me out.
Old Mar 26, 2010 | 01:43 AM
Wrathernaut's Avatar
Gentle Manne of Leisure
See the search this forum thing? It's a few inches to the right of the New Thread button.
Search for Bose Bypass.
Find a relevant post, post a link to it and what questions of yours it didn't answer.
If you're too lazy to get rid of the > > >
> > > >crap out of your post, I'm too lazy to search for you.
Old Mar 26, 2010 | 03:40 PM
lol
thanks !!!
i did search before posting. i will post what i am confused on
Old Mar 26, 2010 | 03:42 PM
Deezflip's Avatar
look
up
balanced
inputs
Old Mar 26, 2010 | 06:05 PM
Factory speaker harness wiring colors
Front Right + Gray/Silver
Front Right - Yellow/Silver
Front Left + Green/Silver
Front Left - Red/Silver
Rear Door Right + Brown/Silver
Rear Door Right - Black/Silver
Rear Door Left + Green/Yellow
Rear Door Left - Black/Yellow
Rear Deck Right + Blue/Red
Rear Deck Right - Blue/White
Rear Deck Left + Blue/Yellow
Rear Deck Left - White/Green
Head unit output colors
Head Output Front Right + Orange/Blue
Head Output Front Right - White/Blue
Head Output Front Left + White
Head Output Front Left - Orange
Head Output Rear Right + Blue
Head Output Rear Right - Pink
Head Output Rear Left + Teal
Head Output Rear Left - Purple
Remote Wire Light Blue/ Silver
these are the outputs from the HU to the bose amp if I am correct.
I can tap into the signal from the 2 connectors that go into the bose amp right ?
Old Mar 26, 2010 | 06:15 PM
okay I think I understand a little better now.
I have splice this for the amp input
and then I have to splice into
give the low level inputs from the 4 channel amp to the monoblock
and output signal from mono block to
Am I correct ?
Old Mar 27, 2010 | 12:49 AM
Looks right to me, just run your own 4 gauge power wire and put your own ground in and you should be good to go.
Just don't blow out the Bose speakers. They're used to taking power from that little cigarette lighter under the rear deck.
Old Mar 27, 2010 | 04:22 PM
gl35's Avatar
make sure your amp will take balanced differential inputs or it will sound bad when you turn it up past the halfway to two thirds point.
I ran into this problem, what I ended up doing was putting an MTX REQ5 in, which takes balanced differential inputs and puts out unbalanced RCA outputs. THIS IS IMPORTANT to consider!
Old Mar 29, 2010 | 06:37 PM
balanced or unbalanced, hmm, not sure, my amp takes low level inputs from RCA, and it takes high level inputs like the direct speaker wires. not sure about balanced or unbalanced :|
this amp (4 channel) i did not buy for myself as it was a gift, been 2 years i have it sitting around so i thought i would install it.
amp specs are :
Continuous Power: 75w x 4 @ 4 ohms
120w x 4 @ 2 ohms
Bridged Power: 180w x 2 @ 4 ohms
Maximum Power: 150w x 4 @ 4 ohms
230w x 4 @ 2 ohms
Frequency Response: 5 - 100k Hz
THD: 0.04%
Signal to Noise Ratio: 90db
Remote Volume Control Option: Yes
Damping Factor: 205 @ 4 ohms
Dimensions: 28cm x 44cm x 6cm
its an "ultimate sound" company which i have never heard about.
http://teamalltech.com/description_502.html
Old Mar 29, 2010 | 07:57 PM
gl35's Avatar
well
You are taking the old Bose amp out correct?
If the amp does not specifically say balanced differential inputs, then it is most likely unbalanced.
Are you going to run it into the high level inputs? OR are you going to take the signal from the Bose HU to the new amp. If so, this balanced differential business is going to matter.
Old Apr 6, 2010 | 01:14 PM
That is something i cannot find much info about. I find alot of technical stuff that is not registering correctly in my small brain.
well i have not done this yet but i am trying to take out the bose amp and add 2 amps instead of the one. So taking the output before it goes into the amp and taking the stock amp out using my own amps. Thats not a good idea you guys think.
Old Apr 6, 2010 | 01:54 PM
Any plan that involves removing the Bose amp and replacing it is a good thing.
Since it don't see anything about a new headunit in your posts, it seems your best course of action right now is to make sure one of those amps can take a balanced signal, and that that same amp also has pre-outs to send to the other amp.
Re-using the stock wiring to the trunk, and from the trunk to the speakers, it shouldn't be very difficult to install. Just don't try and re-use the amp power wire or ground. Run your own.
Old Apr 6, 2010 | 01:59 PM
gl35's Avatar
Great Idea
That is exactly how I did it. Now you need to either get an amp that has Differential Balanced Inputs (JL Audio or Xtant are a few) OR get a device that does. I used an MTX REQ5. I got it for about $100 on Amazon.com.
What I did was kept the stock HU, tapped into the low level (equivalent to RCA jacks) signals, and fed them into my MTX REQ5, then into both amps. IF you do not get something with Differential Balanced Inputs (MTX REQ5, JL Amp, etc...) when you turn it up about 2/3 of the way it will distort horribly, crackling and popping.
If you still need some more help, you can PM me if you need.
Good luck, hope it works out.
Old Apr 6, 2010 | 05:24 PM
Awesome. Thanks for all your help. I will look into that and i hope i should be fine.
Picture Share
Feb 4, 2018 12:41 PM
g.spot
May 9, 2016 10:54 PM
DEMoLITIoN
Audio/Video/Electronics
Apr 20, 2016 06:57 PM
hrdwirk1
Oct 2, 2015 06:34 PM
