Window Rail / Runner
Old May 27, 2010 | 02:00 PM
The Stimulation's Avatar
I'm sure some of you guys have deadened your doors. Looking primarily for response from the sedan guys as I think coupes may be different.
I'm having issues getting the window rails / runner aligned with that black metal piece covering the door. On the coupe I believe there is a bolt that comes from the inside of the door and a nut that screws on from where the black piece is.
For the sedan, I think it's just a bolt with a washer on it that goes directly onto the black metal piece into the window rail to keep the rail from sliding.
Anyone have pics with their door panel off exposing all the bolts on the door panel or know what it's supposed to be like?
Old May 27, 2010 | 02:42 PM
Wrathernaut's Avatar
Gentle Manne of Leisure
Check out this thread donpisto -
https://g35driver.com/forums/audio-v...adening-g.html
Plenty of pics with exposed door guts. More than just in the first post, scroll through.
Old May 27, 2010 | 02:52 PM
Thanks for the link....there's one pic I found that shows what I'm talking about.
As circled, you can see the coupe has bolts in it coming from behind the window runner.
I'm wondering if the sedan is the same. Here is a pic of mine before I removed everything:
What I recall is them being bolts that go through the black metal piece and into the window runner. After I remove the bolts, this is how it looked:
As you can see, I don't have a bolt sticking out as shown in the first pic. That's why I'm wondering if the coupe and sedan are different. Or maybe if they are, I need to mimic how it's done with the coupe.
Old May 27, 2010 | 11:37 PM
I can't see your pics for about 12 more hours since I'm at work. If you're not doing this any time soon (month or so) I'll have a full write-up from when I do my car.
Headunit + amps + speakers + 4080 + sub + deadening.
Gonna be a fun few days.
Old May 27, 2010 | 11:58 PM
Tryin to get the doors on within a month, they've been off for several weeks already lol.
Looking forward to your writeup.
Old May 28, 2010 | 12:10 PM
So you're just having trouble re-assembling it now?
Check out page 77:
http://www.psedog.com/cars/fsm/g35/sedan/2006/gw.pdf
Old May 28, 2010 | 04:21 PM
Well, getting the runner lined up with the black piece. I finally got it, and it didn't take much effort or time this time around.
The sedan is different. As I had recalled the sedan has bolts that go into the black metal piece and then into the window runner. The coupe has a bolt going into the back of the window runner and out through the black metal piece. And from there a washer and nut is attached to the bolt.
I had to use some ********* to hold the runner in place while getting the bolts in on the upper ones, lower ones weren't so bad. Unlike the coupe, the sedan wiring is in front of the black metal piece, not behind.
Thanks for the help wrathernaut.
Old May 28, 2010 | 04:58 PM
Man hands are a required tool for every job.
Manuals occasionally help.
Old May 28, 2010 | 05:42 PM
Most definitely. I think it helped that the windows were rolled partially down. And I think originally my problem was that I didn't do the motor reset.
Dallsinghjr1
Sep 17, 2023 11:25 AM
Picture Share
Feb 4, 2018 12:41 PM
BradMD_96
Oct 6, 2015 09:31 AM
dcsbh1
Oct 1, 2015 03:15 PM
Learned Hand
Oct 1, 2015 09:02 AM
