where to hook up remote wire for amp
i ran a jl1000 with a 10w7 sealed jl box now 1 problem i used a loc for the inputs, everything is good except for the remote wire, there are wires running thru the trunk any of them i can tap into, tired of using a switch i forgot one night and just killed my battery. thanks for your help btw its 04 g35 sedan
Re: where to hook up remote wire for amp
On the sedan, it is a green with a white stripe wire in the trunk, on the coupe, it is different. There is a DIY in the DIY section that says which wire it is for the coupe.
'03.5 Silver AT Sedan, Premium, Aero Kit/Package, Sport, Winter, Stillen Air Box, Z pipe, Polk Tweeters, Clifford RSX 3.5, 19" Gram Light 57F Pro's, Hotchkis sways, Borla
Did you read my post? Do you have a sedan or a coupe? Don't start tapping into wires unless you know which one it is. On the coupe it is different then the sedan. I want to say it is blue, but I didn't say that originally because I didn't know for sure. Check the DIY section!
I just hooked up my system last week, and double checked my shop manual. The acc wire is the green with a white stripe in the harness for the stock amplifier (located under the rear deck in the trunk). Maybe you tapped into a different green/white wire. I am positive on this.
Yes, it would have. Here is a pic of the schematic. I believe it should be a light green wire. It says LG.
