where to hook up remote wire for amp
Old 10-11-2004 | 11:43 AM
khsonic03's Avatar
Re: where to hook up remote wire for amp
I am assuming that it stands for light green. The other way of telling is that the schematic has a diagram for the wiring harness. If you look at the pic, the wire is #10 for acc. The diagram at the bottom for the harness (m40) has #10 in the upper left hand corner of the harness disconnect.(with the click tab facing upward)---do it like that.
'03.5 Silver AT Sedan, Premium, Aero Kit/Package, Sport, Winter, Stillen Air Box, Z pipe, Polk Tweeters, Clifford RSX 3.5, 19" Gram Light 57F Pro's, Hotchkis sways, Borla
Old 10-11-2004 | 11:54 AM
platnum525's Avatar
im tapping in thru the trunk so i dont know which harness im looking at but theres a bunch of wires in the trunk against the back seat area in the trunk that extends to the rear fender of the trunk. so ill try light green later but i had seen on a site that it had every color and what it was for i cant seem to find it it was almost like what the shops have the program that tells you what every color is in the car
Old 10-11-2004 | 12:30 PM
khsonic03's Avatar
Well, in that case I am not sure. I don't believe there are any wires running to the trunk area unless you have a Bose system. This harness is the one that plugs into the back of the HU. You could tap in there and run a new wire back to the trunk where your amp is. Other than that, someone else with a base system would have to help you. According to the shop manual I have, there is no acc wire in the trunk area.
Old 10-11-2004 | 12:57 PM
platnum525's Avatar
ok what if i take off my drivers side kick pod are theyre any cables running thru there or driver side sill anything i can run thru there
Old 10-12-2004 | 09:33 AM
platnum525's Avatar
any help????
Old 10-12-2004 | 11:51 AM
khsonic03's Avatar
I don't believe so. I would have to look into it more. (check the shop manual) Anyone else?
05-22-2022 09:26 AM
Ninjay16
Audio/Video/Electronics
11
02-26-2018 06:14 PM
g.spot
05-09-2016 10:54 PM
VatoVazq
Steering & Suspension
12-23-2015 10:01 AM
Quick Reply: where to hook up remote wire for amp
