Finished installing Pioneer avic-x920bt
Old Sep 27, 2010 | 01:24 PM
freshwun's Avatar
I got a Pioneer avic-x920bt to install in my 03 G35 since I was having the infamous A/C and radio shorting out issue. Got a sweet deal of $486 after rebate from Amazon.
I just wanted to say thanks to everyone especially Wrathernaut for the detailed information on how to install everything. I used the jdm kit, Pac-Nis2, and Pac-SWI to do the install. I was able to get the navi bypass done and program the PAC-SWI. I got too lazy to add the dual climate button. Plus I rarely use it anyways. Everything in Wrathernaut's instructions are accurate. I'll post some pics later. Thanks again.
Old Sep 27, 2010 | 02:12 PM
Wrathernaut's Avatar
Gentle Manne of Leisure
$486 for a X920BT is just stupid cheap for that headunit.
Glad everything worked out for you , and if somebody's needing help with an install in your area, you're obliged to help now. They are, of course, required to provide you with refreshments
Old Sep 27, 2010 | 02:14 PM
Unleaded91's Avatar
Congrats on your install!!
I will be doing the same with my 03 g35 coupe real soon..
How difficult was the navi bypass setup?
Old Sep 27, 2010 | 02:22 PM
The only thing hard about the bypass is getting the old pin out. Once you realize that you can cut the harness quite a bit to get it out, it's pretty easy. The tough part is convincing yourself to go at it with a box cutter.
Or you can order replacement pins and not even have to remove the wire for the bypass:
http://avic411.com/forum/viewtopic.php?f=57&t=33378
Old Sep 27, 2010 | 02:26 PM
blazeplacid's Avatar
how did you get it down below $500?
Old Sep 28, 2010 | 09:38 AM
bina12834's Avatar
ill be throwing a x920bt along with new speakers and amp in my G soon. Everythings just sitting in my room at the moment....its hard to look at it everyday.
Old Sep 28, 2010 | 10:14 AM
M3Tuner44's Avatar
Are you able to use the stock amp for the front and rear speakers or did u just use the built in amp to power them?
Old Sep 28, 2010 | 12:43 PM
Yes, you can use the stock amp, that's why he went with the PAC ROEM-NIS2, to ensure that it'd work right.
Old Sep 28, 2010 | 01:25 PM
M3Tuner44's Avatar
Alright yes so then that would make sense. Would it be beneficial at all to use the outputs from the headunit to power the speakers themselves, or does i not have enough power.
Old Sep 28, 2010 | 02:22 PM
A good stereo probably outputs just as much as the Bose amp does and bypass the horrible EQ built into the Bose amp, but I don't think anybody's every taken the time to actually measure the output of the Bose amp.
Old Sep 29, 2010 | 09:03 PM
freshwun's Avatar
The original price on Amazon was $800 about two weeks ago. 30% off of that and plus $100 rebate. Sweet deal! The easiest way to get out the pin was to use the boxcutter like Wrauthernaut said.
I think the hardest thing was putting the steering wheel interface together since I haven't soldered in forever and had to make sure the resistors stayed connected to the wire (thanks for the pen tube tip Wrauthernaut).
I don't think the eco graph is working on the unit though. I thought the vss wire was the white/green wire that was on the steering wheel interface harness so I tapped that. Too much trouble to take everything out to troubleshoot so I just left it as is.
Old Sep 29, 2010 | 09:33 PM
M3Tuner44's Avatar
Well now you gotta get some pics up. I bought this same headunit and am planning on installing it in about 2 weeks. How is the navy on it. I installed ecplipse headunits in some of my other cars and I hate the nav on it.
Old Oct 1, 2010 | 11:21 AM
freshwun's Avatar
Here are some pics I snapped with my Blackberry. There is a small gap on the bottom of the unit that I haven't fixed yet.
I haven't used the navi that much yet but it worked well when I did use it. I like the POI(points of interest) option and the ability to say where you want to go on the navi.
Attached Thumbnails Finished installing Pioneer avic-x920bt-img00156.jpg   Finished installing Pioneer avic-x920bt-img00158.jpg   Finished installing Pioneer avic-x920bt-img00162.jpg
Old Oct 1, 2010 | 02:45 PM
If anything else, they're great shots to show why you want the $10 trim ring.
Old Oct 1, 2010 | 02:46 PM
Oh, and the eco graph won't work until you refill it and tell it how much gas you put in at least once or twice.
